Hey..
I have some interest in building a boost converter. My demands are following: Input voltage 13-14.5V DC Output voltage 19 at 5A. i do not think that a small amount of ripple is a problem. The but! i have never had experience with boost converters before. i have a couple of different coils and toroids that i hope i can use. i had an idea of using something like 80khz to drive, but i have seen in other forums that you use around 50khz in SMPS?... what would you recommend?.. I have enclosed a design idea. - made something like that on breadboard, but uses voltage reg on input (which get hot), it outputs from Vin-0.5 to 27.8V the transistor is BUZ20, cant remember name of diode, but it should be fine, have also tested different coils. |
#2 |
I have already tested without regulator on a 12v gel battery.
switching freq is around 120khz works fine with a computer fan as load. right now my max voltage is around 17v. 230ma and at 12v it is 130ma. cant remember the usage with no load at 17V. if i post a picture of the coil can some of you possibly tell me if it suitable to use as my coil for the real booster? |
#3 |
I would suggest using the National Semiconductor LM3478. I used it before to boost 12 volts to 20 volts at about 5A for a former employer.
http://www.national.com/pf/LM/LM3478.html - Richard |
#4 |
It looks really promising, but i would like to do it analogue.
mainly because i have made a breadboard that works, i already have the needed components, but also to have a better understanding of what is really going on.. the only thing i really need to know it which switching freq would be suitable, and which inductor i should use.. but i will remember that component as it is easy to use later on.. |
#5 |
The choice of switching frequency is a function of different factors that you want to consider in your design. Usually frequencies from 20kHz (above audio) to 1MHz or above can be used.
The thing is - the higher the frequency, the smaller the inductor (magnetic components). However, as the switching frequency increase, the switching losses becomes more and more significant.... A good compromise between switching losses and inductor size is 100kHz. |
#6 |
thx.. some of that i already knew..
it was more if some one could give a more specific freq range, like 40-50... but the freq also depends on the inductor right?.. - is there a easy way to find the optimal switching freq of my inductor. I have a scope and function generator at hand, and a good multimeter.. |
#7 |
I recommend you some books where you'll find your answers:
Fast Analytical Techniques for Electrical and Electronic Circuits - Vatche Vorperian Switch-Mode Power Supplies Spice Simulations and Practical Designs - Christophe Basso Fundamentals of Power Electronics (2nd edition) - Erickson & Maksimovic Switching Power Supplies A to Z - Sanjaya Maniktala (I love the style is written) |
#8 |
Using a just comparator at feedback is asking for problems IMO.
You rather need a limited gain with lowpass to create a more "analog" feedback signal. P.S. I hope what you have done is either keep mosfet off or switch at 50 duty cycle... |
#9 |
Something more like this..
which kind of problems do you thin it will result?.. |
#10 |
The reason i have added the zener (not a 6v but a 5.something Volt)
is to prevent the duty to be over 50% (actually lower with a lower value zener) so if the feedback fails or there is overload the duty will not exceed a certain level.. |
| need help for basic boost converter! | roomi | Power Supplies | 5 | 30th December 2008 07:11 PM |
| 250 W boost converter for 12 V car battery | Bootstrapper | Power Supplies | 29 | 22nd September 2008 10:52 AM |
| design of boost converter | zilog | Power Supplies | 10 | 25th August 2008 09:09 PM |
| what use for a boost converter ? | Tekko | Power Supplies | 12 | 27th December 2006 10:09 AM |
| Designing 5A Boost converter | Bakmeel | Everything Else | 3 | 14th January 2004 11:57 AM |
| Page generated in 0.16030 seconds (84.98% PHP - 15.02% MySQL) with 11 queries |
