is there a cheap volt reg ic for above mentioned spec? the xmer rating is 18 0 18 v 2amp
#2 |
I just usually use the LM317 & LM337 adjustable regulators with a couple of trimpots to adjust. Works great, and these parts are generally less noisy than the fixed regulators (or so I'm told). I've used them at exactly +-16V for the fivefish.net SC-1 mic preamps (fivefish sells a nice linear power supply kit of this type for $35 -also includes +48V for phantom power for mics-- I'm not associated with fivefish in any way, but admire his work).
Frank |
#3 |
Use the LM317 option... If you're afraid to run short on current, use a simple power transistor as a parallel pass device. How to do that is written in the LM317 application notes.
More Power Igor! More Power! |
#4 |
Or u may paralel 2/3 LM317 for higher current
| Max PSU voltage with SI T-amp | jives11 | Class D | 2 | 2nd July 2007 01:12 PM |
| Should I use high voltage value zeners or multiple lower voltage zeners in series? | jarthel | Parts | 7 | 30th May 2006 04:56 PM |
| Rail Voltage to Capacitor Voltage | Mermprin | Parts | 6 | 20th September 2004 03:56 PM |
| secondary voltage vs. primary voltage | Stocker | Parts | 5 | 11th March 2004 07:41 PM |
| Rail voltage compared to transformer voltage | SteveG | Solid State | 4 | 22nd July 2002 11:50 PM |
| Page generated in 0.07027 seconds (67.62% PHP - 32.38% MySQL) with 10 queries |
