Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd January 2009, 07:30 AM   #1
Solve is offline Solve  Sweden
Solve's Avatar
Default One trafo-two amps?
I have an iron trafo from an broken Denon amp that i going to use
with an Tripath TA3020 amp but now i just wonder if its possible to use two amps driven in paralell from same trafo?
Ofcourse i understand that i loose effect.
My plan is to use it in two way active via an Behringer DCX2496.
The trafo is giving about +/- 60v.
Music is the only art in real time....
Old 23rd January 2009, 11:06 AM   #2
Yes it is possible. You could use two bridges with seperate caps if you want.
/sreten.
Old 23rd January 2009, 11:38 AM   #3
Solve's Avatar
Thanks for the answer.I think about two bridges later, good idea.
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
SE Trafo for PP use dsavitsk Tubes / Valves 15 8th August 2007 08:27 PM
Help with trafo Hojvaelde Tubes / Valves 1 13th February 2006 08:12 PM
Of what value is this trafo? wxn Parts 7 13th June 2005 12:08 PM
Trafo to buy for PWM amp partyjups Solid State 6 19th December 2001 10:32 PM
Page generated in 0.07355 seconds (66.77% PHP - 33.23% MySQL) with 11 queries
