SMPS for "isolation": 120in-->~100dc out??
Old 11th January 2009, 04:36 PM   #1
bear is offline bear
expert in tautology
bear's Avatar
Question SMPS for "isolation": 120in-->~100dc out??
Any SMPS gurus here?
Here's what I want to accomplish:
AC Line in ---> smps w/galvanic isolation--->~120vdc out (that can be anything between ~90vdc and ~130vdc (the low end is actually better). Regulation need not be terribly tight, but I need >500watt power level, up to 1000 watt is better.
Simple, efficient, and fairly easy to get the HF hash filtered out are important considerations. No problems to use an off-the-shelf chip solution or combo of standard building blocks. Can probably wind/build a suitable core/transformer (probably).
Any ideas, directions, schemes would be appreciated so that I don't have to go and become an "instant expert" and make all sorts of basic mistakes...
I haven't even seen a brick that does this, which is part of why I am considering building one for my application.
Help!!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 12th January 2009, 08:43 AM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
TI parts search recommends the UCC3580 according to the your requirements. It says it's good for up to 800W. Maybe something worth looking at.
Old 14th January 2009, 05:05 AM   #3
expert in tautology
bear's Avatar
Aw heck, I'll just become an instant expert...
Thanks for the tip on the TI part, I'll look into it...
_-_-bear
_-_-bear
SMPS for "isolation": 120in-->~100dc out??Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
smps 12vdc to 30vac for "beginner" dudio_me Chip Amps 0 12th December 2008 08:54 PM
SMPS -- "safety and the 5 cent zener" jackinnj Solid State 2 28th October 2004 03:44 AM
"Palestinians and the Isolation of the Intifada" millwood The Lounge 35 24th July 2004 06:48 PM
Copyright ©1999-2017 diyAudio
