Building a class II PSU (double insulated, no safety earth) - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th January 2009, 10:38 AM   #11
Default OOPs
My mistake.
Send me back to school.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th January 2009, 10:52 AM   #12
MondyT is offline MondyT  United Kingdom
No worries my friend!
I hope the info helped
Cheers
Ray
Old 12th January 2009, 01:18 PM   #13
mr.duck is offline mr.duck  United Kingdom
Originally posted by richie00boy
How about a different approach. Use an AC-DC plugtop converter which is class-II to start with, the modern switch mode ones are very compact. Then simply put additional filtering and regulation inside your equipment case.
It's nice idea. But if you want +/- supplies you need at least 2 of them. Plus the higher power one such as 120W look like they have an earth connection, so it can be limiting if you can only use the lower power models. I looked into filtering them but I thought it can cause unexpected headaches. Such as the inductors used in the filter can radiate noise into the audio circuits. Plus I'm not sure if SMPS can be completely restored to a clean voltage? And finally would feel the need to have a linear voltage reg if there is lots of CLC or CRC filtering to make a nice low impedance supply. So it would work but is much less ideal
connecting audio ground to Safety Earth AndrewT Power Supplies 41 30th May 2011 10:50 AM
B1 pre earth safety question (newbie) scorpio1 Pass Labs 2 16th June 2009 04:30 PM
Please help with safety earth using wood enclosure A Sanchez Chip Amps 7 27th June 2008 08:25 AM
How many types of Class D on Earth?? Leolabs Class D 13 14th February 2007 12:13 PM
first I earth the chassis for safety but why do I need to conect it to my ground... frank2395 Pass Labs 4 20th May 2005 12:15 PM
Copyright 1999-2017 diyAudio
