Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th January 2009, 08:34 PM   #1
Default I would like to design a power supply
I Would like to design a power supply. My design requirements are 2000 watts of power with serious circut protection and at least a 50% overcapcity tolerance.. I am a bit lost as to where to begin. I have a very basic understanding of how they work and some basic EE knowledge but selecting the right topology as well as the math involved seems a bit daunting.
I need 100v +- for rail voltages and a 12 volt supply at roughly 2 amps to leave enough head room for any preamp add on's
as I understand it a full bridge topology may be the best topology to use but I haven't seen many good article describing how to build such an aniimal and alot of the article seem to be a bit over my head so to speak.
I would almost gladly purchase a premade product for this useage to save the aggervation and my relative inexperience at engineering complex electrical products also prove duanting. . I would also gladly compensate a compotent engineer to do the design to save me the exspense of burning up lots of parts.
So that being siad where do I begin on this journey of oddly simplistic complexity ??
Old 7th January 2009, 08:47 PM   #2
the Quasi thread.
regards Andrew T.
Old 7th January 2009, 09:06 PM   #3
It might help if you told us what this would be powering, how tight you need the voltage regulation, will this be used for long periods of just for a moment or two ect.
Old 7th January 2009, 09:10 PM   #4
Music Amplifaction long duration and I would like to see tight control. It will be a full range application but I will be splitting the outputs into a bi-amp layout. I plan on using a good deal of capcitance to help with low tone reproduction but It will require a very good power supply to avoid clipping.
As to the Quasi thread ?? I searched and did not see thread with the title of quasi outside of the solid state area but that was a power amp not a power supply. I have a power amp design that works I just need a good power supply.
Old 8th January 2009, 07:23 AM   #5
Originally posted by Kramerguy
Music Amplifaction long duration and I would like to see tight control. ........................... the title of quasi outside of the solid state area but that was a power amp not a power supply. I have a power amp design that works I just need a good power supply.
there is little wrong with a transformer + rectifier + smoothing.
adjust the smoothing value to suit the required bass response and speaker impedance.
Transformer VA from 2kVA to 4kVA for 2kW output.
regards Andrew T.
Old 8th January 2009, 01:45 PM   #6
I am trying to save wieght. IT is a big concern with gigging the head to lug another 27+ lbs of transformer.
Also do you know anythign about this quasi thread ?
Old 8th January 2009, 04:10 PM   #7
That's a change to the brief.
regards Andrew T.
Old 8th January 2009, 08:21 PM   #8
I am sorry I didn't mention that earlier. Dooohh.
Old 9th January 2009, 08:28 AM   #9
contact Eva.
A world of knowledge on SMPS and similar.
regards Andrew T.
Old 14th January 2009, 05:50 PM   #10
I would gladly pay Eva for knowledge or a design.
Paging Eva. My email adress is in my profile.
contact Eva.
Power Supply Design Defbrett Tubes / Valves 28 9th October 2009 11:54 PM
48 VDC/10 A power supply looking for an Amp design Analog Addict Solid State 16 16th January 2008 10:39 AM
need help with a power supply design lochness Power Supplies 1 31st October 2007 05:12 PM
Power Supply Design whitelabrat Power Supplies 8 29th May 2007 03:14 PM
Power supply design LeakSt20 Parts 0 16th August 2005 03:06 PM
Page generated in 0.11000 seconds (80.96% PHP - 19.04% MySQL) with 10 queries
