Another Linear Pass Regulator - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd January 2009, 09:39 PM   #11
cbdb is offline cbdb  Canada
Is Cjo the main junction capacitance that determines Ft?
Old 3rd January 2009, 09:44 PM   #12
No, it's Cb'e in the hybrid pi model. Actually, Cb'e is determined from fT. Cjo is applicable to a diode, but the transistor capacitances are Cje and Cjc. Note that Cje is not the same as Cb'e.
Old 3rd January 2009, 10:23 PM   #13
keantoken's Avatar
Thank you.
Lower Cjo transistors are more stable in high-OLG places, and have less of a tendency to oscillate.
Besides, I've noticed that low Cjo transistors usually have high transition frequencies as well.
I don't know if you're suggesting I use an opamp, but Q5 and Q6 are a diff. amp. It has a voltage gain of about 8, where the input is the voltage between the two bases and the output is the voltage from collector to collector. This is called the Rush cascode, and it has specific benefits over the LTP.
I am not worried so much about temperature stability, although I don't know how much it is prone to wander in real life.
I will look at that modeling book, but that thing is HUGE and I will need time. I am curious about how I might tweak models to fit the datasheet curves better.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 3rd January 2009, 10:59 PM   #14
keantoken's Avatar
Scratch that. I've looked through my models and there isn't much correlation between Cj values and Ft. Hmmm.
- keantoken
Old 13th January 2009, 08:33 AM   #15
keantoken's Avatar
Anyways, I've had much trouble getting anything to keep from oscillating if I used transistors with too much Cje.
This might actually have something to do with simulator settings. I've recently discovered that if I set the maximum timestep to a lower value, the oscillations go away!
So this circuit is actually more stable than the simulator is showing it to be.
Recently I learned about this thing called a miller compensation cap, which also increased stability. I also replaced the CCS on the zener with a bootstrap.
D10 and D6 form a protection circuit for Q3, as large load spikes will cause Massive currents to flow through Q3's base otherwise. The Rush cascode is an amazingly fast device!
Here is the schematic:
- keantoken
linear regulator question rtate Digital Line Level 6 17th December 2008 02:36 PM
Modular Linear Regulator TheDriver Parts 0 28th July 2008 07:27 PM
Linear Pass transistor regulator - my design keantoken Power Supplies 49 5th July 2008 10:24 PM
Linear regulator eltonseemann Power Supplies 10 1st November 2007 03:44 AM
Linear regulator for power amp mr.duck Power Supplies 3 10th April 2007 10:59 AM
Copyright 1999-2017 diyAudio
