Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th December 2008, 03:59 PM   #1
Default Wiring for balanced power ?
All things being equal, what geometry would you do for balanced 240 in (120+/120-) into a step down trafo and balanced 120 out (60+/60-) given three discrete conductors that you can manipulate however you desired? I was thinking just twist the two 'hots' and then wrap the ground around that and sleeve it, but are there any other ideas out there? Like braiding it? This wil be 3 x 8ga in and a pair of 3 x 12ga out. 37kva trafo 40 amp in 2 x 20 amp out.
http://usr.audioasylum.com/images/1/16530/4a11_12.jpg
Old 29th December 2008, 08:13 PM   #2
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
The best practice for wiring high-current lines is to make sure feed and return are twisted together.
On the transformer primary, the centre wire will probably not carry a lot of current assuming the voltages are well enough symmetrical.
On the secondary, it mostly depends on your loads, and if you have thre freedom, make a 4-wire scheme on the secondary.
Take one wire from each outer transformer connection, and two wires from the transformer centre tap connection. Twist one outer wire together with one centre wire.
Bakmeel
More Power Igor! More Power!
Re-wiring to balanced (tonearm) Doctorcilantro Analog Line Level 5 12th October 2010 09:25 AM
help wiring these power tx riotubes Parts 14 16th November 2008 01:06 AM
If you are looking to try balanced AC power.... KBK Tubes / Valves 85 7th December 2006 05:42 PM
power and wiring thewillman19 Car Audio 0 17th December 2005 08:20 PM
Standard wiring for 5-pin balanced input? paulb Parts 1 18th February 2002 11:10 PM
Page generated in 0.07404 seconds (69.83% PHP - 30.17% MySQL) with 10 queries
