Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th December 2008, 11:19 PM   #1
gary h is offline gary h  United States
Default Transformer primary winding question
Hi all,
This is as simple as it gets, but then again, so am I;
I have a transformer that supplies 40-0-40 to a 260W amp. It's primaries are wired in parallel and are connected to a 120V main.
I would like to use it in a circuit requiring a 20V supply. I assume I can wire the primary in series to achieve this? That is, wire the primary for 220-240V but give it 120V?
If I understand correctly I will get half the voltage but what about current considerations, will this harm the transformer?
Thanks,
gary
Old 21st December 2008, 07:59 AM   #2
Elvee is offline Elvee  Belgium
Hi
You won't harm anything, but you'll halve the available power (the maximum current remains the same), and the regulation will be rather poor.
On the other hand, the no-load power input will be very small.
Old 21st December 2008, 11:03 AM   #3
Thanks. I'll give it a try.
Old 21st December 2008, 11:26 AM   #4
hi,
wait.
The transformer will be capable of half VA when run at half voltage.
The 40-0-40 gives ~+-58Vdc after the rectifiers.
When run at half voltage it will give ~+-29Vdc not 20Vdc.
You could regulate down to 20Vdc, but you are wasting a good transformer that is capable of so much more.
regards Andrew T.
Old 21st December 2008, 06:21 PM   #5
Hi Andrew,
the circuit I have in mind is a gainclone using the lm3886 chip. (I built one of these recently using Peter Daniel's boards and am very happy with it.) I think that 26VDC is right in the chips speced range so I wouldn't need to bleed off any more voltage there. I am concerned about losing the power though. If the transformer is rated at 260 Watts, I have been told that I will end up with about 30-35 Watts if I run the primary in series. This might just be enough for a small pair of 4 Ohm speakers.
PD mentioned possibly keeping the 40V rails and employing active regulation to get the voltage down. If I'm correct this will probably equal the cost of a new 22V transformer I should just order.
But I'm trying to salvage what I can from this fading amp I have, it would be so nice to just replace the circuit and leave the (pricier) chassis, tranny, etc. as is.
cheers,
gary
Transformer primary rating question gary h Tubes / Valves 2 26th June 2008 06:24 PM
Question about bifilar primary winding vectorplane Power Supplies 3 19th October 2007 10:16 PM
Question about caps on transformer primary speakerguy79 Power Supplies 2 24th April 2007 10:17 PM
transformer winding question gearheadgene Power Supplies 21 25th January 2006 07:12 PM
Multiple primary power transformer question trombone Tubes / Valves 7 23rd May 2005 04:36 PM
Page generated in 0.08394 seconds (71.59% PHP - 28.41% MySQL) with 10 queries
