which ferrite beads for mos legs?
I've noticed my mosfet psu is quietly oscillating and I've put a ferrite bead in both gate and drain legs. This has "shut it up"and now runs much cooler. Since mos oscillates well into UHF, I chose a material with a fairly low permeability i.e mu=700 philips 4A11 pink . Is this the correct approach and /or what is best ferrite material grade to use. Or broadband ? Anyone got any experience ?
richj |
I don't know.
But I like know. |
This thread is so necro...:)
But if you cool Mosfets tend to "oscillate" when the are hot so the same effect could be obtained with better cooling. |
Its been 25 years and I dont remember what worked best for my application but Fair-Rite makes a nice little evaluation kit. I seem to remember material 43 but could be wrong.
Sorry this isn't much help, the kits were still available just a few years back. -Antonio |
Usually a ferrite bead on the gate should be sufficient. The mu and the losses in the material need to be just high enough so that the oscillation stops with a good margin.
Alternatively, you might beef up the gate driver and/or reduce the gate drive resistor, or move it closer to the gate. Or, chose a older (slower) MOSFET - the new superjunction devices (think Fairchild SuperFET or Infineon CoolMOS) are getting faster and faster.... just my two cents... |
| All times are GMT. The time now is 06:18 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
