Peak Current in SMPS
I am working at SMPS , using gate drive transformer.
But the design i have does not include any diodes at the outputs of the gate drive transformer secondary, between G and S.
I am unable to determine IF those diodes are responsible for burning my Mosfets so quick!
What Zener values I should use, and can those help?
Schematic is below, please watch the part ZNR1, in the schematic. is it there for PEAK CURRENT protection? instead of the ZENERS?
Thanks All
  • smps.pdf
dtproff
dtproff
many thanks for your link, I started to read more about the power supplies around, and i found that the A-and-T-Labs power supply, will NOT work as the design shows, since driving those heavy mosfets needs attention.
Driving them Directly from the GDT is useless, putiing that ciruit in place will make things much , much better,
The A-and-T-Labs power supply is a bit of a scam, but the website continues in place and they are probably selling some from time to time. I think this was already discussed in some thread one or two years ago.
Are there at least 5mm of creepage between the mains live primary side and the isolated output side on the PCB?
No, it dosn't have that. It's quite scary, take a look:
http://www.a-and-t-labs.com/K6_Sw_Amp/art_schematic/k6pwr-comp.pdf
http://www.a-and-t-labs.com/K6_Sw_Amp/art_schematic/k6pwr-sold.pdf
