Simplistic Mosfet HV Shunt Regs
Old 25th January 2010, 10:53 PM   #951
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Originally Posted by massimo View Post
Read what I wrote: not in the Salas's shunt circuit
This means that the real Simpler Simplistic starts at the positive leg of C1?
"It is less serious than if worst"
Old 25th January 2010, 11:08 PM   #952
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
He just combines an independent low voltage heater supply on the same board of his. Using it for whatever.
Old 25th January 2010, 11:16 PM   #953
iko is offline iko  Canada
iko's Avatar
I see a lot of potential for confusion and sparks; the circuit lends itself very well to point-to-point wiring. This will also force you to read the schematic carefully and check your work well. Using someone's less the thorough tested pcb is quite risky.
Old 26th January 2010, 08:34 AM   #954
quanghao is offline quanghao  Viet Nam
Simplistic Mosfet HV Shunt Regs Send a message via Yahoo to quanghao Simplistic Mosfet HV Shunt Regs
That small choke should be in the Heater PS section of the pcb, not in the Salas' shunt.
Hi! that is my filament
You can see in the image!
Old 27th January 2010, 12:00 AM   #955
Mosquito's Avatar
Sorry, I still can not see a clear answer on this. Let me expose it in another way.
Suppose that one just want to use the regulator stuff, and want to have the raw DC supply completely off board, in case of using your board, is it to be filled starting at C1, while ignoring everything that comes first on the schematic of post 943...?
Old 27th January 2010, 12:08 AM   #956
massimo is offline massimo  Italy
Old 27th January 2010, 12:14 AM   #957
Mosquito's Avatar
finally...!
Old 27th January 2010, 12:22 AM   #958
Sorry but yesterday when you asked first I couldn't open schem of post #943 (don't ask me why) and thus identify C1.
Anyway pics and schematics on page 1 tell you all.
Drink a mate for me!
Old 27th January 2010, 03:39 AM   #959
Mosquito's Avatar
Done!
Old 3rd February 2010, 10:03 AM   #960
Salas's Avatar
Originally Posted by Sorr View Post
It has been sometime since the low voltage (+18.6V & -18.6V) regulators were posted.
Are there any updated/improved versions of this circuit?
This is the high voltage reg's thread. 200-350V etc.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
