Simplistic Mosfet HV Shunt Regs - Page 56 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th October 2009, 01:15 PM   #551
disco is offline disco  Netherlands
disco's Avatar
Originally Posted by quanghao View Post
This is my pre for output DAC.
6C45pi is notorious for oscillation, there's some info on applying cathodestoppers (!) at diyaudio.
jaap
Old 8th October 2009, 01:38 PM   #552
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Can you show me what is link! about 6c45pi
Thank
Old 8th October 2009, 01:47 PM   #553
iko is offline iko  Canada
iko's Avatar
Hey quang, do you have one shunt regulator feeding both pre channels? How much current does each preamp channel draws?
I think you setup your shunt reg current limit too low. This could explain the voltage so low on the output.
From your measurements it shows that the total current through R1 is 47mA = 2.21V / 47R. Seems a bit low.
Old 8th October 2009, 01:54 PM   #554
Hi ikoflexer! help me!
do you have one shunt regulator feeding both pre channels? = yes one shunt for two chanel my pre!
17ma one chanel!
What Do i can?? for mya pre? and Shunt?
QuangHao
Old 8th October 2009, 02:04 PM   #555
iko's Avatar
OK, let's see. You got 47mA total going through. If you are 100% sure that each channel takes 17mA, then 47 - 17 - 17 = 13mA. That is the total current that is left for biasing and shunt mosfet. I think that's too small. Make R1 just a little smaller value and measure everything again. Do you have a resistor around 40 ohm for R1? You could use two 75R in parallel.
Also, insert a 1R or a 0R1 resistor between the source of Q3 and ground, and measure the voltage across it, with the circuit powered.
You're working with high voltage, be careful! I see you don't have a bleeder resistor in your PSU filter. Your caps retain high voltage, so make sure they are discharged when you work on the circuit.
Old 8th October 2009, 02:12 PM   #556
Ok! I try to do that!
Thank! let wait for me!
Old 8th October 2009, 02:39 PM   #557
iko's Avatar
What takes you so long?
Just kidding, take your time and above all, do it safely!
Old 8th October 2009, 02:58 PM   #558
ok! i change r= paralle 75 R R1 =35R. V= 2.16 v!
An R 1 r = 226V!
ok or no??
Old 8th October 2009, 03:02 PM   #559
iko's Avatar
Looks a bit better now. I also asked you to insert a 1 ohm or a 0.1 ohm resistor between the source of Q3 and ground, and measure the voltage across it, with the circuit powered. Have you done that?
Old 8th October 2009, 03:12 PM   #560
Looks a bit better now. I also asked you to insert a 1 ohm or a 0.1 ohm resistor between the source of Q3 and ground, and measure the voltage across it, with the circuit powered. Have you done that?[/QUOTE]
Yes, I do that!
My pre is stil ees ..esss ! * not change*
I do sample you show!
I use 1R between Q3 to ground and V= 220V.
i think my pre use tube 6c45, Is is noise!
I check my pre!
Thank
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 05:49 PM
Copyright 1999-2017 diyAudio
