Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th August 2009, 05:49 AM   #501
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
2 driver tubes at 20mA each total of 40ma.That would be 6,8w double the current 80mA=13,6w.
Regards Åke
Old 29th August 2009, 11:41 AM   #502
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The CCS Mosfet can take up to 200V across it. Haven't used such a Vin - Vout though. You are talking 170V at 80mA through it. I would at least clamp it with a 190V 5W Zener across and 12V 0.25W Zener from G to S, as well as the output one from S to G, directly on the pins. All Zener cathodes looking up as we view the schematic. Because a small transient would kill easily at such margins. R1=33R at 170Vdiff for 80mA. On the other hand, why not kill some voltage on a series of RC filter stages, so to get the dif down to 70V and benefit by pre smoothing the reg's final Vin a lot?
Old 29th August 2009, 11:56 AM   #503
Ryssen's Avatar
Ok,thanks.
Regards Åke
Old 29th August 2009, 12:42 PM   #504
Stixx is offline Stixx  Germany
Stixx's Avatar
I eventually got the headphone amplifier breadboarded that my first HV shunt was intended for. As a reminder: SE spud using D3A, C3G or E810F (playing right now), vintage Saba opt's and so on...
For testing I initally used a Maida reg at 145V since the Salas' shunt is a bit more ...err... sensitive to prying around with probes, disconnecting and connecting and such
The sonic result wasn't exactly overwhelming (even after burn in) so I put the shunt regulator to use.
and to Salas again! Don't want to repeat myself too often, but what a difference! The shunt is playing at 75mA for about 42mA consumption at 142V (the lower limit of the trimpot) and beats the Maida by a very comfortable margin... Open, sweet, subtle and authentic... very nice!
Old 29th August 2009, 01:23 PM   #505
nicoch58's Avatar
well done !!
Ps don't use mdf is carcinogen.....
Old 29th August 2009, 03:04 PM   #506
Salas's Avatar
Good to know it has served you well in several occasions. Happy listening.
Old 8th September 2009, 04:45 PM   #507
disco is offline disco  Netherlands
disco's Avatar
Still waiting for those A94 to arrive...
Nice bottles you use for the headphones Stixx.
Is the schematic on line?
jaap
Old 8th September 2009, 07:10 PM   #508
Stixx's Avatar
Those bottles are 6D22s halfwave rectifiers... the rest is a very straightforward single tube SE-schematic.
The schematic is now online , shown with the D3A though.. Also bias is now with an orange LED at around 21mA for the E810F.
Not sure about this tube yet, also i am still having a tiny bit of hum on one channel probably due to wiring...
Next in line is C3G which I am using successfully in another headphone amplifier.
Old 8th September 2009, 07:54 PM   #509
Ryssen's Avatar
Do you have a picture with higher resolution?
Regards Åke
Old 9th September 2009, 08:11 AM   #510
Stixx's Avatar
I should be readable when you fully enlarge it (first zoom it and than extend in lower left corner).
Regs - Shunt vs Series richie00boy Solid State 4 27th November 2003 08:09 PM
Page generated in 0.13310 seconds (73.64% PHP - 26.36% MySQL) with 11 queries
