#41 |
diyAudio Chief Moderator
Not really, use red. The greens group better statistically, that is all. You use so little CCS current in your case, that if you get some more or less, there will be no dissipation or starvation penalty.
#42 |
I got to listen to the HV shunt late last night, background is "blacker", overall sound is faster without harshness, voicing and timber has improved. I'm running one per channel in the line stage. Needless to say the Lambda No. 28 is now up for sale. Didn't think anything would beat the LCLCLC filter and the No. 28. I have tried the Allen Wright SuperReg and the Janus, both have ICs. While both are very good, I prefer the KISS approach and it does sound better. Anyone who is looking for a GREAT simple shunt regular, this IS the way to go. Again a big "thanks" to Salas.
#43 |
Cygnus,
very interesting comment! So, the Salas's regulators sound better even of a chocke input PSU ? This is very good news. I have searched this "Lambda n 28" but no result. Can you please post a link ? Thanks Cheers, Paolo |
#44 |
Just started going through my parts bin to collect parts for a hv shunt build (over xmas?) and checking what will have to be ordered.
I am having a bit of a hard time determining the size of the mosfet heatsinks...(my application B+ ~200V max at 36mA). Trying to read up on the subject turns up very scientific explanations at great lenght, but sure there is some handy formula for this... Will a heatsink with 2.5K/W be enough (120x32x50mm)?? |
#45 |
Yes, that heat sink should be enough for your application.
#46 |
inertial
The Lambda No. 28 is a vintage labratory tube p/s regulator from the 50s (lambda is still producing lad grade p/s). Kind of like the Kepco. I was going to post it in the marketplace, once I found the documentation and schmatic. Email me and I can send you a picture and I will dig through my files to find the docs. Compaired to the Salas HV shunt, it is more conjested sounding, not as fast, not as "black" in the background. The fact that it is a series regulator, puts a lot of components in the HV rail, along with the all the inductors and caps, muddies up the HV rail (all that inductance and phase shift from the caps). My line stage (type 340 DHT, CCS, parafeed OPT) is very revealing and dependant on a clean, stable, low noise and low inpeadance supply. Because it has a high plate resistance, I wouldn't even try to run this tube without the CCS and parafeed OPT, the typical resistance loaded, cap coupled output, just doesn't "sing". Give the Salas HV Shunt a listen. |
#47 |
Oh, thanks cygnus,
I understand. I have talked with my fiend and he is disponible to make a Sala's prototipe circuit for me. Unfortunately he is very busy at the moment but he hope to find a bit of time to make it into acceptable time...........I hope the same! cheers, Paolo |
#48 |
Salas,
what is the expected voltage drop across the regulator? I don't want to burn excessive voltage in the heatsinks and size the transformer accordingly... Thank you... |
#49 |
I would like you to drop 50V because it sounds better. But it can work from as low as 10V drop.
#50 |
alrighty... 50V it will be then.
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Regs - Shunt vs Series | richie00boy | Solid State | 4 | 27th November 2003 07:09 PM |
| Page generated in 0.10362 seconds (62.34% PHP - 37.66% MySQL) with 11 queries |
