#481 | |
#482 |
Correlation between shutter speed and refresh rate?
jaap |
#483 |
diyAudio Chief Moderator
Very possible.
#484 |
Last week I did a pcb design for this circuit. Since a couple of days I've got two of them working on a small (2A3) amplifier. They do a good job regulating and sonics are very good. Dynamic, precise but musical I would comment.
There are a few peculiarities about the circuit board. - when the output is shorted, you'll have to replace the semi's ![]() Some simple alterations can make it fool proof. More on this subject will follow; - C1 (100uF/10V) is at a high potential. Do not touch while live if the can is not isolated; - connecting wires shouldn't have excessive length for best results; - for R2 and R7 it's better not to use metal film; - R2 is mounted at the back; - R3 and R9 (in the higher voltage version) are 82K/5W. If you can't locate these there's space to double a 150K/2W and a 180K/2W. These resistors get hot on full 400V!; - the initial version suffered from heat building up in Q2 so I had to use a heatsink on the small TO-92 transistor. It occurred while the reg was dissipating 45mA at 295V into Q3 (over 13W). This renewed board is more spacious for better air flow around the components; - if necessary a 47 ohm base stopper on Q2 can be inserted by breaking the copper trace between Q2 and C2 (see purple trace). Hope you enjoy it as much as I do
jaap Last edited by disco; 24th August 2009 at 03:00 PM. |
#486 |
#488 |
The link works in my browser but here it is again, attached.
#489 | |
![]() First tests were on a bench power supply at 345V input, 50mV ripple. Second I made a 340V PSU with 2.3V ripple (ok, that's a lot). Last I improved this PSU to 350V with 0.7V ripple (not too good either). Both PSU's used small caps and a 10H choke, ripple was sinusoidal. The voltage margin (input to output) was 40 to 50 volts, current margins were circa 50% to 40% (75mA to the load, 40mA to the sink etc). With all tests I measured no AC at all after the reg. ![]() Regarding the second part of your reply, I'm constructing a straight forward 2A3 amplifier to test the several regulators I've built so far. There's metalwork involved so it takes some free float to complete.
jaap |
#490 |
The link is OK, the problem might be a temporary unobtainable host because of 'data stress'. If not send me a PM.
jaap |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Regs - Shunt vs Series | richie00boy | Solid State | 4 | 27th November 2003 07:09 PM |
| Page generated in 0.11890 seconds (65.05% PHP - 34.95% MySQL) with 11 queries |
