Simplistic Mosfet HV Shunt Regs
Old 9th March 2014, 11:24 PM   #4321
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
SSHV2 has more resolution and neutrality. Previous is bit rounder or "warmer".
Old 27th March 2014, 09:40 AM   #4322
jcastellano is offline jcastellano  Spain
Question SSHV2 problem
Dear friends,
I have just finished an SSHV2 and I am having a problem with it. I bought the kit from Tea-Bag and I feel it is well stuffed. I am feeding it with 180V raw DC, I can adjust the current (in my case 60ma, so at TP I read 600mv) but I only got 25 volts output. Adjusting R11 I con go up to 40 volts but no more. The led is lit and I tested R11 to be in the range of 1k as stated in the manual. The sink of the IRF840 is cold whatsoever.
Any clues?
Best Regards
Jorge
Old 27th March 2014, 02:55 PM   #4323
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Diodes are OK?
If yes, check both KSA1381 & SK117GR.
Good luck
Felipe
Old 27th March 2014, 03:06 PM   #4324
Salas's Avatar
Check if the dummy load is using up too much current also, if so it is starving the whole voltage setting parallel part of the reg.
Old 27th March 2014, 06:26 PM   #4325
Hi Salas,
I am using a dummy load rated at 3.3k and 17watts. I am trying to achieve 200v with 60ma current ( 40 for the phono preamp and 20ma spare ). My transformer is rated at 180v sec 100ma, after rectifier and cap bank, should be around 240volts, plenty enough for regulation.
Hi Felipe,
Checked everything and look fine. Gracias...
Thanks and regards,
Jorge
Old 27th March 2014, 06:38 PM   #4326
R.I.P.
Your transformer secondary has too low a current rating for a continuous 60mA+CCS.
You need at least a 120mAac secondary but much cooler to use a 240mAac rated secondary.
If you want to source 40mA into your dummy load @ 200Vdc, then the load should be around 5k. 15W to 20W is sufficient rating.
That you are getting only 25Vdc at the output indicates another fault.
regards Andrew T.
Old 27th March 2014, 07:21 PM   #4327
Salas's Avatar
Originally Posted by jcastellano View Post
Hi Salas,
Hi Felipe,
Thanks and regards,
Jorge
First test is to use about 5K dummy load. Since the shunt part tries to do some voltage now and adjusts but stays low, you must eliminate the heavy test loading parameter first and then see what might be next or not. Lets hope that the large in-out differential it suffered did not manage to take out some semis. After better set/repaired you should evaluate the transformer's temperature also because its marginally current rated as Andrew noted.
Old 24th April 2014, 02:18 PM   #4328
zeeuw is offline zeeuw  Netherlands
Dear Salas
Just faced a problem.
If F+ is shortcutted the S+ drops to zero.
The 12v zener does then not protect the KSA, as the KSA has a max BE of 5 volt
So KSA is broken down (as also the zener)
Pls comment
Sander
Old 24th April 2014, 03:17 PM   #4329
Salas's Avatar
"Shortcutted" means F+ shorted to GND?
Old 24th April 2014, 03:41 PM   #4330
Yes
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
