Simplistic Mosfet HV Shunt Regs
Old 25th October 2013, 10:04 AM   #4241
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Old 25th October 2013, 01:28 PM   #4242
king4joy is offline king4joy  Hong Kong
Old 15th December 2013, 05:28 PM   #4243
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Any changes to the circuit posted in #2061? Any part changes?
47uF before the regulator
20VDC headroom
minimum 20mA extra current
20mA (assuming minimum is used) * final B+ dissipated by Q3
Q1 dissipates (20mA + load current) * 20VDC headroom
Old 15th December 2013, 09:06 PM   #4244
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No changes. Your summary is correct too.
Old 15th December 2013, 10:24 PM   #4245
luvdunhill's Avatar
That's quite the testament to your design! Congrats! Given a 20mA load could I get away with 15 mA - 18mA shunt current instead of the recommended 20mA?
Old 16th December 2013, 12:42 AM   #4246
Salas's Avatar
You could, it will only be bit worse in spec, but no tragedy. Run it at even 30mA spare when you will have the sinking, the change is audible enough form 15mA.
Old 16th December 2013, 01:38 AM   #4247
roger57 is offline roger57  Canada
roger57's Avatar
Salas,
What changes to SSHV2 for 100V input, about 70 to 80V out?
Old 16th December 2013, 01:44 AM   #4248
Salas's Avatar
You gotta scale down the two same value I/V resistors R9,R10.
Old 16th December 2013, 01:47 AM   #4249
roger57's Avatar
Will give it a try, thanks!
Old 16th December 2013, 05:30 AM   #4250
poty is offline poty  Russian Federation
I see this confusing...
20mA extra current is above MAX (amplitude) current, not quiescent current, so the dissipation for Q3 should be (20mA -5mA +(Imax - Io))*Vb+,
where
Imax - amplitude current
Io - quiescent current
Vb+ - final B+
5mA - this current is reserved by BJT cascode and sensing circuit.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
