Simplistic Mosfet HV Shunt Regs
Old 17th August 2013, 06:00 AM   #4051
stajo is offline stajo  Sweden
My start for removing HF noice would be a small, 10 nF or so 1000 V poly or silver mica right after the rectifiers. Even more effective would be to use (C)-L-C choke input and start with the 10 nF. In practice it would act like choke input (DC=0,9xAC). Very effective also for HF
Old 17th August 2013, 06:47 AM   #4052
Originally Posted by merlin el mago View Post
In my PSUDII simulation the last RC 1 ohm 3uF just before the load increase the ripple.
Circuit is oscillating. Increase last R from 1 to 10 Ohm
But really. Trying to combine DHTRobs passive filter layout with active filtering changes the whole idea. I think you should ditch that. Putting resistance after the shunt just puts their good job in the closit. Short twisted wires directly as close to the load as possible from shunts, nothing inbetween. If HF noice/trancients is a problem, try decoupling near bridge.
Old 17th August 2013, 07:25 AM   #4053
Sims 1 and 10 ohms for visualisations
Old 17th August 2013, 08:41 AM   #4054
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Originally Posted by Salas View Post
Just change the sensing resistor to 1 Ohm now. Looks like it will push the borderline just so that may prove a good help.
Right, so got this now sorted and is working like a charm. Increased raw supply to allow output voltage increase but small drop in the CCS, changed CCS FET and added bigger heatsinks to minimise temperature drift at maximum current. To run this regulator at 85-90mA you need them clearly! Thanks for the tips
See further notes here: Adjusting the shunt regulator | Bartola Valves
cheers,
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 17th August 2013, 09:24 AM   #4055
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Can't do it because I need B+ before SSHV2 minimum 300VDC
If I increase resistor value change the filter value
Also you reduce ripple if you increase the value of last capacitor but the same problem like resistor = value of filter will change
Old 17th August 2013, 09:25 AM   #4056
I think I'll let it go and run without filter
Old 17th August 2013, 09:35 AM   #4057
How did you conclude that you have a HF noice problem? How does it look like, what is the frequencys? Or is it a Citroen-thing: Beautiful solutions to none existing problems
Old 17th August 2013, 09:38 AM   #4058
Because in other PSU for other load I compared with or without filter and my ears prefered with filter.
Old 17th August 2013, 09:52 AM   #4059
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
cheers,
Ale
Happy end then. And a nice documentation of the proper utilization moves. Congrats.
Old 17th August 2013, 04:00 PM   #4060
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
This in itself is no evidence for the presence of HF noise. It may stem from various reasons.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
