Simplistic Mosfet HV Shunt Regs
Old 13th May 2013, 02:08 AM   #3941
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by JBLman View Post
What part? To place the Zobel cap right or not to exceed the top Mosfet's spec? Both should be watched. Crt could had marked it better I am not sure, but here is an "X-RAY" of the C1 area.
Old 13th May 2013, 04:51 PM   #3942
JBLman is offline JBLman  United States
Ok thanks!
Old 13th May 2013, 08:35 PM   #3943
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
I failed both! it wasn't clear to me the PCB marking, but not blaming anyone as it seems I was the only one who did this
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 13th May 2013, 11:56 PM   #3944
Yea, I don't know it only puts out 58vdc and can't adjust it.
Old 14th May 2013, 12:27 AM   #3945
Salas's Avatar
Ale
I will ask Crt to mark it more intuitively for the future when I will catch up with him and he has some time. Interestingly nobody reported so for missing the C1 placing, but its mainly because they use longer capacitors is my guess. Thanks for the feedback, very nice website you got BTW.
Old 14th May 2013, 12:40 AM   #3946
Salas's Avatar
All semis show proper VGS, VBE, warm up, etc.?
Old 15th May 2013, 06:48 AM   #3947
mogliaa's Avatar
Thanks for the feedback. My intuition led me to place it centred given the multiple holes.
Ale
Old 21st May 2013, 07:43 PM   #3948
lucek12 is offline lucek12  Poland
Hi Salas,
I would like to buy the pcb or the whole kit- pcb+parts. Would it be possible?
Old 30th June 2013, 12:29 AM   #3949
eboz is offline eboz  United States
Send a message via Yahoo to eboz
Default SSHV2 temp drift
I recently purchased and assembled a kit from Tea-Bag. Is there any likely suspects when the sshv2 is slowly decreasing in voltage as it warms up? My heatsink is more than adequate, and I have another sshv2 that has been stable in operation for over 6mos. It seems to be temp dependent, since I can blow around the board and get the voltage to drop or stop dropping for a moment. I may have zapped a device on assembly?
Also, after it has been dropped in voltage a lot (say 5 or 10 minutes), it will begin to swing more wildly. I can compensate for the drop by turning the voltage adjustment trimmer.
Old 30th June 2013, 12:33 AM   #3950
Salas's Avatar
Its normal to drift with temp due to the semis tempco in the Vref but not wildly. 2-3V. Leave it warm up for 15mins and then set for Vo. If it continues drifting in the tens of Volt then something's not right.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
