Simplistic Mosfet HV Shunt Regs
Old 15th April 2013, 12:53 AM   #3871
JBLman is offline JBLman  United States
Thank you!
Old 18th April 2013, 12:47 AM   #3872
multi is offline multi  Australia
Default Mosfet ripple filter
HI.
I built a 572b amp the out put transformer was so big could not fit a choke to the box.
Does not have any hum even on 100+db horns but I would like to fit a mosfet regulator/ ripple filter.just for the driver tubes about 40-50 ma
I found the circuit for a mosfet ripple filter in AudioXpress Jan 2001 for a 3cx300 amp. circuit attached.
3cx300 amp runs at 450 volts about 240ma; mosfet only drops a few volts. i have 630 volts.
Do you think this circuit would handle 630 volts at 60ma; I have a irfc60 and some 200 volts 5 watt zeners. Would any one have a pcb for this circuit?
Phil
Old 19th April 2013, 05:45 AM   #3873
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its a series design that its dissipation is going to be what voltage is across the IRFPC times the current it passes obviously but I don't think anybody has shown it in this thread before so to expertly tell you if it scales well or needs some modification.
Old 19th April 2013, 10:35 AM   #3874
Thanks Salas;
I will try it and see what happens.
Phil
Old 3rd May 2013, 04:49 PM   #3875
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Salas I can only get regulated 28VDC, the red LED lits, any suggestions where to start? could be Q6 SK117GR?
TIA
Felipe
Old 3rd May 2013, 04:55 PM   #3876
Salas's Avatar
That, the near Zener, and the BJT pair.
Old 3rd May 2013, 05:00 PM   #3877
Yes.
Old 3rd May 2013, 05:24 PM   #3878
DCA55 say SK117GR faulty component
Old 3rd May 2013, 06:11 PM   #3879
Q5 KSA1381 also faulty componentnow is working OK again
Old 3rd May 2013, 08:53 PM   #3880
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Salas,
May order some custom transformers in my Primrose Gb for this amp and was wandering if dual transformers was necessary for dual regs, and if not, what VA rating shoulf the single transformer be. I was thinking single 800VA or dual 400VA.
...Shape the sound , Man!
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
