Simplistic Mosfet HV Shunt Regs
Old 6th April 2013, 10:20 AM   #3861
R.I.P.
Long >=6" 150mm
Short <=1" 25mm
regards Andrew T.
Old 6th April 2013, 11:35 AM   #3862
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by AndrewT View Post
Long distances defeat the main advantage of regulated supplies, namely low output impedance.
Long distances must have high impedance.
To get the benefit of regulated supplies the regulator should be right next to the client circuit.
The higher the current slew rates the worse this problem becomes.
At very high current slew rates, using regulators on long distance leadouts is a waste of resources.
Remote sensing does not solve long distance powering.
Completely agree is not sense to make a very good regulator and place it long distance from load.
Old 6th April 2013, 12:06 PM   #3863
iko is offline iko  Canada
iko's Avatar
Guys, I don't need to be convinced of the technical benefits, because to me it makes sense. If you look back I was the one pushing for sense/force wires in the old days when we extended the low impedance of v1.0 (low voltage) by adding the extra bjt source follower. I was just wondering if anyone could hear the difference, that's all.
Edit: basically I'd just like to know for myself, out of simple curiousity. Anecdotal evidence would be enough for me.
Old 6th April 2013, 04:09 PM   #3864
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Kazuo san got rather impressed of what 4 wires could do for his burgeoning Reflektor experiments although he was not convinced due to short distance and was using 2 wires at start. I could feel it was worthwhile in most applications too. Both in low V and high V. 4 wires connection can be more prone to EMI is one danger and if without a scope some perceived harshness is tell tale. It can almost always be remedied if it happens by proper wiring dressing and/or some extra sense loop decoupling at the reg. People can subjectively check 4 VS 2 wire on their own application by shorting F+ to S+ and F0 to S0 locally at the reg connector with short jumpers and do A to B critical listening so to respond back to your anecdotal statistical query. No use of the soldering iron is needed if 4 wire mode is already there. The local shorting will effectively make it into 2 wire for the curious to evaluate.
Old 7th April 2013, 01:42 AM   #3865
iko's Avatar
Thanks Salas!
Old 13th April 2013, 11:04 PM   #3866
JBLman is offline JBLman  United States
Hey guy's I'm new to the sshv2 I was wondering when setting it up are you guys using the ma needed in the formula to calculate the resistor value? Here's what I mean, I need 19ma w/ the drop off of 20ma that equals 39ma. So, 310v/.39ma = 793 ohm so a 800 ohm resistor or is it 310/.19 = 1631 a 1.6k ohm resistor.
Could someone let me know, Thanks!
Old 14th April 2013, 12:02 AM   #3867
Salas's Avatar
Its 310/0.19 since you need simulate just the load consumption not to drain the whole CCS. A 1K5 10W standard part or 1K6 should do.
Old 14th April 2013, 12:39 AM   #3868
Thanks! will do!
Old 14th April 2013, 11:27 PM   #3869
So now that I have that, I'll be adjusting the trimmer to 390mv correct? The .19+.20 for reg. drop.
Old 15th April 2013, 12:47 AM   #3870
Salas's Avatar
Yes.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
