Simplistic Mosfet HV Shunt Regs
Old 17th March 2013, 11:56 AM   #3841
Alex M is offline Alex M  Europe
Originally Posted by Salas View Post
Its the latter. A "snubber" or Zobel network more precisely. Voltage drop across that resistor will be insignificant because it just poses "ESR" there. That capacitor has all of it across in essence. The values are critical enough and better not be altered unless someone optimizes damping for a specific load evaluating with lab gear. In general its a little wonder how this design interfaces with so many people's stuff without a multitude of major drama stories. One thing is I don't push the spec too far on purpose, it could be impressive to have 1/3 the now Zo and 3x the now bandwidth, but it would not be generally easy to get widely applied with simple means and no deeper understanding effort. There is a point of diminishing returns subjectively also, so its a juggling act to make a useful general purpose solid state HV shunt reg with some field success. Until now it seems serving the goals rather satisfactorily is my impression. The main purpose is to bring good tonality regulation in compact space with better damping for little money and weight VS iron clad traditional passive filtering cells. A rail hum killer with added value and good sonics in other words.
Thanks - that makes sense.
Alex
Old 17th March 2013, 01:03 PM   #3842
euro21 is online now euro21  Hungary
Originally Posted by stajo View Post
.. DN2540 CSS and the shunt mosfet on the same sink..
This is my #26 preamp SSHV2 regulator.
250V input, 220V/ 5.5+5.5 mA output (cCCS are 20mA).
Heat sink about 45 degree Celsius (after 4-5 hour).
Old 23rd March 2013, 04:03 PM   #3843
stajo is offline stajo  Sweden
Goodafternoon. Before I solder away, is it S+/S0 that makes one twisted pair and F+/F0 that makes the other, according to recommendation?
Old 23rd March 2013, 04:07 PM   #3844
R.I.P.
What does S+ represent?
Once I have that I should be able to work out the other three.
regards Andrew T.
Old 23rd March 2013, 04:19 PM   #3845
massimo is offline massimo  Italy
S for Sense and F for Force (Vout) I guess
Old 23rd March 2013, 04:20 PM   #3846
R.I.P.
.......... is it S+/S0 that makes one twisted pair and F+/F0 that makes the other,..........
Yes.
All flow and return pairs must be close coupled.
And that includes ON the regulator PCB and ON the Receiver PCB.
regards Andrew T.
Old 23rd March 2013, 04:30 PM   #3847
Correct. Usually its only plus (signal, hot,) and minus (return, cold) that shall be twisted in general application, but I'm not sure what Salas recommended here.
Old 23rd March 2013, 04:38 PM   #3848
Thanks Andrew. Needed some moral support
Old 23rd March 2013, 05:08 PM   #3849
merlin el mago is offline merlin el mago
merlin el mago's Avatar
S0 & F0 soldered togheter at the load S+ & F+ soldered togheter at the load.
Old 5th April 2013, 01:34 PM   #3850
Default My SSHV2: a photo
As promised, here is a photo of the two SSHV2 regulators installed in my RTP3.
There is a definite advance in stability and presence over the (probably malfunctioning) HPHV regs they replaced.
Alex
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
