Simplistic Mosfet HV Shunt Regs
Old 13th March 2013, 08:59 PM   #3821
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Originally Posted by ikoflexer View Post
Makes no sense to put a ccs on the ground/return wire.
That may depend on what one wants the CCS to accomplish.
Old 15th March 2013, 09:55 AM   #3822
regal is offline regal  United States
Has anyone tried parallel mosfets in order to supply a power tube like a 2A3 or even 300B ?
Old 15th March 2013, 10:08 AM   #3823
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No reference that I can remember of. It is not simple as that if to be tried out though. It will very possibly need an overhaul.
Old 15th March 2013, 11:33 PM   #3824
Joshua_G's Avatar
Hi Salas,
What amount of ripple voltage would be sufficient for the input of HV Shunt Regulator V2?
Old 15th March 2013, 11:40 PM   #3825
Salas's Avatar
Not much over 5VPP would be helpful when having the recommended 20VDC Vin-Vout margin.
Old 15th March 2013, 11:50 PM   #3826
iko is offline iko  Canada
iko's Avatar
In this context, of a shunt regulator, it would accomplish a disaster.
Old 15th March 2013, 11:56 PM   #3827
iko's Avatar
I have tried it on my shunt reg experiments, not exactly this schematic, but similar. The first obvious thing you notice is that the capacitance of the paralleled mosfets is higher. On account of this you lose all that good performance in the high frequency range. So you may as well go for the simplistic version. Also, you can chose much beefier mosfets.
Old 16th March 2013, 12:04 AM   #3828
Joshua_G's Avatar
Thanks Salas.
Though I abandoned this idea, I cannot see why it would accomplish a disaster.
Old 16th March 2013, 12:06 AM   #3829
Salas's Avatar
Anyways a good PSU is needed whatever it is. "It is most important to realise that an amplifier is merely a modulator and controls the flow of energy from the power supply to the load. If the power supply is poor and has insufficient energy to meet the amplifier's peak demands, then the most beautifully designed amplifier will be junk."
MORGAN JONES
VALVE AMPLIFIERS 4TH EDITION page 334.
Old 16th March 2013, 06:55 AM   #3830
I've been running my SSHV1 at pretty stressful conditions ( I thought that the more extra current the better.) It supplies the tube 20mA @180V and dumps an extra 40 mA, V-in is about 230V with a big heatsink. Its been stable for a year (red PCBs.)
So I don't think supplying an output of 65ma +20ma @370 is too much of a stretch for the SSHV2. Especially with the new IXTY-TA-TP08N50D2 depletion mosfet at Q1(which can be mounted to the off-board sink).
I think a TO-247 like IRFP450 , would sub for Q3 ?
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
