Simplistic Mosfet HV Shunt Regs
Old 22nd January 2013, 02:26 PM   #3781
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Originally Posted by Salas View Post
The HIFI2000 website needs revision to more intuitive and comprehensive IMHO.
I'd second that.
Old 22nd January 2013, 04:02 PM   #3782
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by massimo View Post
P.S. La Porxada, is that a nice place for tapas?
I don't know if still exist, the lighter have 19 yeas old when I was living in Barcelona and yes the chef was excellent......
Old 25th January 2013, 12:26 PM   #3783
Brouilly is offline Brouilly  United Kingdom
Brouilly's Avatar
Pictures for Salas
Almost done with my compressor, still trying to sort out the last instability issues at fast compression, but it's almost there. Last bits, just adding a SS/valve side chain switch.
Promised some photos so here you go! It's going into Ocean Sound Studios in Alesund, Norway. New mix room being built there and this will be the first custom unit
One question - the LEDs on both boards are the same type but one shines brighter than the other, is this something to be concerned with? The boards are running very well, but thought i'd ask anyway.
Thanks for your efforts!
Charlie
Broke solderer with delusions of grandeur
Old 25th January 2013, 12:47 PM   #3784
regal is offline regal  United States
With the SSHV2 how hard is the 400V limit? I'm looking at 400V 30 ma op +20 ma, big heatsink so OK there but what sets the 400V max ?
Old 25th January 2013, 01:17 PM   #3785
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by CSlee View Post
Pictures for Salas
Charlie
Nice stuff. Congrats on your custom soft knee valve compressor.
For same output voltage there ought to be same current set via the Jfet sources that runs through the LED to the Vref 68K resistors. Therefore same type leds should shine about the same excluding some possible luminosity variation from sample to sample. Just because there are two circuits and two regs, try to scope if there is something different going on with sense points or there is some VHF oscillation in one that finds its way back and the higher brightness is a clue. Or the dimmer brightness for that matter.
Old 25th January 2013, 01:43 PM   #3786
Brouilly's Avatar
I have tested all the points and they all read the same. My scope isn't great but it doesn't look like there is any VHF oscillation. Unless there is on both boards - it just looks like noise to me. About 2mV - is that about right for this reg?
If there is oscillation what might be the issue? A ground loop?
Thanks!
Charlie
Old 25th January 2013, 01:47 PM   #3787
Salas's Avatar
Its the spec of the upper cascode DMOS that recommends no more than 400Vin. The output Enhancement Mode 842 has 500V spec already. And there are the PCB isolation distances being challenged, heat rising on output MOS and the cascode BJTs the more you push it up, transients can be hard etc. Roger57 had installed and tested a 500V Q1 with success, see posts #3397-3406.
Old 25th January 2013, 01:55 PM   #3788
Salas's Avatar
Thanks!
Charlie
When on a rail AC coupled to a scope and seeing a straight line, then 2mV Pk-Pk thickness of random nature can be anything radiated in the total circuitry or picking environmentally by the test loop, it would not alert. If not seeing any waveforms riding then it should be stable. Is it the same display on the sense outlets on the regs themselves?
Old 25th January 2013, 02:01 PM   #3789
Brouilly's Avatar
OK I understand. Yes the same display is on all sense points on both regs.
Going as close as I can with the scope there is a ripple of about 620KHz on both boards, but as you say - it may be something else I am picking up. There is certainly nothing on one board that is not present on the other.
Old 25th January 2013, 02:04 PM   #3790
Salas's Avatar
How high is that ripple? Is it a pure sign wave?
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
