Simplistic Mosfet HV Shunt Regs
Old 21st January 2013, 11:34 AM   #3771
massimo is offline massimo  Italy
Felipe, if I were you I'd rather use a pair of Galaxy Maggiorato (8 cm high). More space inside and alu sides big enough for Coleman's regs and SSHV2 (I think)
That's what I'm planning to use
P.S. La Porxada, is that a nice place for tapas?
Old 21st January 2013, 12:10 PM   #3772
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thanks for advice Massimo, my mistake I ordered Galaxy in place of Galaxy Maggiorato, fortunately I can use the 2nd box for 4P1L preamp so I have to buy the 8 cm high.
Old 21st January 2013, 12:13 PM   #3773
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The HIFI2000 website needs revision to more intuitive and comprehensive IMHO.
Old 21st January 2013, 12:16 PM   #3774
You can just buy the missing pieces, if you wish. Basically you keep the top and bottom cover and buy front/rear panels and a couple of sides.
The galaxy 4 cm is sometime a bit too slim even for solid state projects. That's why I keep on asking them to design a 6 cm high galaxy series, nearly perfect for everything
Old 21st January 2013, 03:46 PM   #3775
Triodethom is offline Triodethom  United States
Triodethom's Avatar
It may be because of the standard rack mount spacing that you get the 4cm high . the 6cm is odd at 1.5 rack space so a 8cm is more likely to happen . Or at least that what it looks like to me.
Old 21st January 2013, 07:01 PM   #3776
Thank you for the advice Massimo but it is not worth still having me with free pieces. I am going to ask for a new box with 8 cm of height but first of all tomorrow I have to check if the 8cm tall will be enough for 1 power tx for B+, 1 choke, 1 tx for AZ1 filaments and 2 txs for Rod Coleman heaters regs.
Old 21st January 2013, 07:11 PM   #3777
Not inside, I dare say. I put the pw Xfrm (HV + Rectifier Fil) and the choke on the top and the two big Xfrms for Rod's reg inside. Then I have rooms for all the caps.
Going to take some pics when I'll have time.
Old 21st January 2013, 07:15 PM   #3778
You're obviously right, but I once (well, twice) made a 6 cm high Galaxy milling the front and rear panels and it looks nice.
Old 21st January 2013, 07:26 PM   #3779
Yes I count to put all txs outside, but my mains power tx for B+ is a Bartolucci double C-Core & choke is also Bartolucci so both are big & heavy, I will post some pics tomorrow.
Salas sorry for OT.
Massimo if you want we will follows by pm or email.
Cheers
Old 21st January 2013, 08:45 PM   #3780
Triodethom's Avatar
It may just come down to how many it takes to have them make 1.5 rack types. That not that a strange size after all 2 of them would be 3 rack space tall . Keep at them and I hope you are successful.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
