Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th January 2013, 11:15 PM   #3761
merlin el mago's Avatar
Yep Salas you are my man, I can use these two nice HIF2000 boxes for my 26 preamp.
Old 20th January 2013, 06:27 AM   #3762
vgeorge is online now vgeorge  Greece
vgeorge's Avatar
Felipe,
maybe the sides of theses chassis are enough for cooling the SSHV2? I think it' s worth a try.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 20th January 2013, 07:23 AM   #3763
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Guys watch the isolation very carefully though. This is HV.
Old 20th January 2013, 07:35 AM   #3764
vgeorge's Avatar
You are right about isolation, but a heatsink the size that Felipe suggest should be supported by chassis somehow, so the caution applies there also.
Old 20th January 2013, 07:39 AM   #3765
Salas's Avatar
It does but it gives the opportunity of double isolation also depending on its chosen mounting to the box.
Old 20th January 2013, 11:07 AM   #3766
Can I use the side chassis for Rod Coleman LV reg?
Old 20th January 2013, 11:07 AM   #3767
regal is offline regal  United States
Just for a little WE417A spud amp I had to use a big case mounted heatsink for best results, it gets hot. Just double triple check insulation.
Old 20th January 2013, 11:23 AM   #3768
Thanks for the nice pic. With this heatsink I don't need to mount outside the chassis, the lighter is only a reference for the size.
Compre Disipadores Disipador de calor,50x100x28mm KL/B/100 AAVID THERMALLOY KL/B/100 en RS Online y lo recibir en 24/48 horas.
Old 20th January 2013, 01:58 PM   #3769
vgeorge's Avatar
I don' t see why not.
Old 21st January 2013, 11:17 AM   #3770
Thanks I will use to safe space inside the box.
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 18.18%)
Copyright ©1999-2013 diyAudio
