Simplistic Mosfet HV Shunt Regs
Old 19th January 2013, 09:20 PM   #3751
merlin el mago is offline merlin el mago
merlin el mago's Avatar
If I can't fit the heatsink for SSHV2 I will use only your CCS & VR150 tubes
Old 19th January 2013, 09:28 PM   #3752
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Noisier, more Zo, but musical enough.
Old 19th January 2013, 09:32 PM   #3753
I read VR150 datasheet and said the minimum voltage operation is 180-185V, do you think will operate with 176,25VDC?
Old 19th January 2013, 09:36 PM   #3754
Originally Posted by Salas View Post
The sinked CCS Mosfet will burn about 1.5W in that case (with ~30mA setting). So a small one like we use for not too hot LM317 situations will do the job.
That's a very good news because I prefer to use all the SSHV2 in my #26 preamp
Old 19th January 2013, 09:36 PM   #3755
Salas's Avatar
Not sure, I have checked some of those only above 200V in the past. Better ask the #26 guys.
Old 19th January 2013, 09:39 PM   #3756
Salas's Avatar
But the output Mosfet will burn 3.5W so its sink better be 3x the size of the CCS one.
Old 19th January 2013, 10:11 PM   #3757
Can be enough this one?
Compre Disipadores Disipador de calor,TO220 3.5degC/W AAVID THERMALLOY KL-100-B en RS Online y lo recibir en 24/48 horas.
Old 19th January 2013, 10:46 PM   #3758
Salas's Avatar
Yep.
Old 19th January 2013, 10:51 PM   #3759
This one 3.7K/W also?
Compre Disipadores Disipador de calor,50x100x28mm KL/B/100 AAVID THERMALLOY KL/B/100 en RS Online y lo recibir en 24/48 horas.
N.B. I have this one on hand.
Old 19th January 2013, 11:05 PM   #3760
Salas's Avatar
Both will do at the CCS and Vo and load you described. They look the same.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
