Simplistic Mosfet HV Shunt Regs
Old 24th December 2012, 06:31 PM   #3691
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by roger57 View Post
Why manual...when "automatic" is available for us lazy types??
Hey Roger57, Merry Xmas. Did you get the chance to audition your amps mods by now?
Old 24th December 2012, 10:28 PM   #3692
roger57 is offline roger57  Canada
roger57's Avatar
Hi Salas!
Merry Christmas to you in beautiful Greece!
I just completed the modifications today and have only listened for a couple of hours. So far, terrific! Recall I have 2 identical Class A amplifiers in passive bi-amp mode on my speakers. The amplifier I modified was the high frequency unit. I find the high frequencies have better resolution and linearity. Extremely nice placement and clarity of vocals. It did what I expected.
However, I ended up having to back off the total current being delivered by the screen regulator. Recall that I required 60mA to the screens at full power output. With the screen current being dynamic, and this unit the high frequency amplifier, I could afford to back the current down to keep the heat sink under 50C, in spite of it's size! I now have adjusted the total current at the test point for 65mA. So far in listening, I believe this will be adequate given the volume I listen at. There are 2 SSHV2 units and a filament regulator all bolted to the same heat sink, so there's a lot of dissipation happening there! I will need to increase the heat sink size on the low frequency amplifier as I will need all the screen current there. No problem as I have more of the same heat sink material and the room on the baseplate to install it. I'll take a couple of pictures later in the week when I have it back in to do some final small updates.
My best wishes to you for a great 2013, and thanks again for everything you do for all who are a part of these forums. It means a lot!
Gary
Old 25th December 2012, 07:19 PM   #3693
Salas's Avatar
A good first impression is 50% chance to sure success. Congrats. More details and few pics as it settles we guess. Merry Xmas.
Old 26th December 2012, 02:07 AM   #3694
king4joy is offline king4joy  Hong Kong
...thankyou for all the helps....I have finished changing Q4, Q5 and the 117 on the questionable board mentioned...I have also renew all the solder joints....I have also added small heat sink with fins to each of the Q4 &5....the 2 boards are now doing 279V in....30mA at TP, and 260V out, with 48V across the 6K loading resistors......they have been steady for more than an hour.....but the Q4 and 5 are still quite hot....and when I blow on them...the V out jumps to 265...it is normal like this??.....I am thinking of adding a piece of aluminum strip the the sink
The photos show the two board installed (no sink yet seen with the Q4 & 5)
Old 26th December 2012, 03:01 PM   #3695
roger57's Avatar
IMO, these are the minimum size you should install on the 2 transistors (Q4,Q5)
274-2AB Wakefield Thermal Solutions | 345-1087-ND | DigiKey
Old 26th December 2012, 03:04 PM   #3696
roger57's Avatar
Default Website Issues?
Salas,
I see you're a forum moderator. Are you aware of any website issues with DIY Audio? Whenever I try to post anything, (the last 3 tries anyhow) I get a warning page from Firefox / Google saying this is a reported "Attack" website.
Know anything about this?
Gary
Old 26th December 2012, 03:18 PM   #3697
nicoch58 is offline nicoch58  Europe
Attack is ok now ,just a little bit of time to google to reload...
Old 26th December 2012, 03:22 PM   #3698
info
http://www.diyaudio.com/forums/forum...ml#post3299614
Old 26th December 2012, 04:12 PM   #3699
Salas's Avatar
Nice photos. When you blow there, yes its normal to drift. There is no ventilation there in your build, so help them Q4 Q5 out with sinking when able.
Old 26th December 2012, 05:16 PM   #3700
roger57's Avatar
Originally Posted by nicoch58 View Post
Hey, thanks for providing this information. It helps to know what's going on and I'm not the only one seeing this!
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
