Simplistic Mosfet HV Shunt Regs
Old 23rd December 2012, 02:59 PM   #3681
king4joy is offline king4joy  Hong Kong
I have not been using sinks on Q4 n Q5....as it has not been showing up as a problem....but after today....I will put sinks on all Q4 n Q5....
Merry X'mas 2U and thankyou.
Old 24th December 2012, 07:07 AM   #3682
What would be the best way to remove solder from a double sided board during repair??
Old 24th December 2012, 08:58 AM   #3683
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Solder wick.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 24th December 2012, 10:31 AM   #3684
Please give details the way to ,use it....melt the solder...then ....how do I use the wick??....do I use the wick on the same side as the iron....or the other side....what if the hold is still blocked??
What is the best way to put the hole back on a used board please??
Old 24th December 2012, 10:31 AM   #3685
hold should read hole.....
Old 24th December 2012, 01:23 PM   #3686
vgeorge's Avatar
Just google and you will find many tutorial videos.
Old 24th December 2012, 01:32 PM   #3687
I shall enjoy doing that...TKS...
Old 24th December 2012, 02:48 PM   #3688
roger57 is offline roger57  Canada
roger57's Avatar
Also, there are 2 different kinds of solder wick. Some have a small amount of flux to help activate the solder joint quicker under heat so the solder is absorbed faster to the wick. I prefer this type for sensitive joints, but in this application (SSHV2 PCB) you probably may not need it.
Old 24th December 2012, 05:17 PM   #3689
vgeorge's Avatar
You can always put some flux manually if needed.
Old 24th December 2012, 06:10 PM   #3690
roger57's Avatar
Why manual...when "automatic" is available for us lazy types??
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
