Simplistic Mosfet HV Shunt Regs
Old 21st December 2012, 12:11 PM   #3661
king4joy is offline king4joy  Hong Kong
Just another silly question: if I set the TP say at 50mA each....will they draw 100mA from my PSU in total??
Will that do no good to my // chokes??
Old 21st December 2012, 12:21 PM   #3662
Will the board draw the current set at TP all the time....
or will it draw only 20mA + load current??
If it only draw 20mA + load current, I do not mind setting the TP at higher setting...
Old 21st December 2012, 12:22 PM   #3663
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes. It will draw what TP says, all the time. Works as a current limit also. Measure what your tubes draw by VRplate/Rplate and just add 20mA each on TP not to tax your Tx and chokes. Tx ducks and chokes drop on their resistance. Factor in any parallel bleeders.
Old 21st December 2012, 12:27 PM   #3664
Should I change the value of the bleeder (now at 150K) so that I can have more room to play around now with 2 boards connected??
I have been playing around with TP setting...and things...but seems PSU is max out to make any meaningful (stable) adjustment with the boards at the moment.
Old 21st December 2012, 12:51 PM   #3665
""...Measure what your tubes draw by VRplate/Rplate and just add 20mA each on TP...""
So it is OK if I may end up with difference TP setting for each board (each tube)....
How do I measure VRplate and Rplate, please?? (I assume that is not the same as the voltage across the 6K load resistor).....
Old 21st December 2012, 12:59 PM   #3666
thinking a bit more....I think by VRplate/Rplate...you mean the current through the 6K load resistor (V across the load resistor/ 6K)....and that should be what each tube is drawing at time....
Old 21st December 2012, 01:25 PM   #3667
Salas's Avatar
Just 2mA bleed at say 300V, so with your value 150K, no considerations.
Old 21st December 2012, 01:45 PM   #3668
So the bleeder is not a worry.......so I think tomorrow, I will try to turn back all voltage setting trimmer way back.....set TP at 30mA...and start from there...
will that change will B+??
Old 21st December 2012, 01:48 PM   #3669
or the chokes are not up to spec of 40mA each...although they are Bartalucci C core chokes....??
Old 23rd December 2012, 07:39 AM   #3670
I have done the above, set both TP at 30mA, voltage into the boards now at 280V, I can then set boards output at 258-260V, with voltage across the //12K load resistor at about 48V...
I notice this time only, Q4 & Q5 are hot...in fact they are the only thing that is hot this time.
Everything cool, until about one hour later.....the voltage out from the new board (the one with brighter LED....suddenly went down to 158V....TP remains at 30mA.....
After switch-off, and half an hour later, upon switch on....TP remains at 30mA, volt out rise to about 200V...
What do you thing has happened??
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
