#3611 |
diyAudio Chief Moderator
#3612 |
Goes up till 137Vout when suddenly 1st fuse broken.
#3613 |
#3614 |
Are there photos and a schematic of the total configuration in blocks? From mains to load?
#3615 |
All zeners are gone, replaced them and tested again the reg., now only crossed D2 so I will replace it and also replace Q2 DN2450.
#3616 |
Crossed again D2, now I will replace all CCS.
#3617 |
Something must be fundamentally wrong when resistors catch fire, parts burn out repeatedly and literally explode...
Being a beta tester of the SSHV I must say that building was very straightforward and easy, so I really wonder.... ![]() |
#3618 |
Fixed the issue was where I suspected at the CCS the track between the two DN2450 was breaked, now I adjust the current to 30mA but the maximum Vout is 151,3VDC, the dummy load is 15K my Vout target is 280VDC Vin is 312,8VDC
#3619 |
Red LED lits.
#3620 |
MJE350 Q4 Emiter Collector soldered togheter
![]() Now works like a charm ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() :e guitar:![]() ![]() ![]() ![]() :ch eers: |
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
