Simplistic Mosfet HV Shunt Regs - Page 360 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th December 2012, 08:11 PM   #3591
merlin el mago's Avatar
Changed 2SK117GR still LED don't lit, checked LED with battery and lits, I will change IRF840
Old 14th December 2012, 08:22 PM   #3592
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Something very wrong is going on there. Something with grounding possibly, and early in the configuration. Make it all grounded or all floating, not half grounded, half floating. That doubler if grounded at totem capacitors mid point and all further caps return there is a +/- source, if at the bottom and all further caps return there is a + polarity source.
Old 14th December 2012, 08:24 PM   #3593
Salas's Avatar
Was there a fuse this time you took out the Caddock?
Old 14th December 2012, 08:29 PM   #3594
Was when connected without fuse.
Old 14th December 2012, 08:31 PM   #3595
Changed IRF840 and LED don't lit (it's very strange) reg. at the input have 365VDC, I will check R11 1K trimmer.
Old 14th December 2012, 09:11 PM   #3596
Verified both trimmers: 1K is good works OK, 200R is burned measured with DVM wiper to ground DVM and both sides reads Megs, changed & tested the reg again LED don't lit Vout 0VDC.
Old 14th December 2012, 09:20 PM   #3597
When testing the reg all is floating gnd: the psu & the reg.
Old 14th December 2012, 09:27 PM   #3598
Salas's Avatar
Isn't there 310-320VDC available without doubling to test for 300V out? Then change all semis including led. Use fuses everywhere. Start with everything floating, ground at one point only, see when fuses are taken out, debugging steps in other words. When the whole config as it is makes its 300 OHM RC cell part in PSU break like being hit with lightning, don't connect up the reg again and again without fusing or reconfiguring, else only same damages will occur.
Old 14th December 2012, 09:29 PM   #3599
Salas's Avatar
No new fireworks in the PSU 300 OHM, that way?
Old 15th December 2012, 10:15 AM   #3600
Yes I have tx 240VAC I will try, yesterday installed two fuses in series separated 2cm 100mA 250VAC, OK first all floating, gnd at only one point, checking fuses.
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 05:49 PM
Copyright 1999-2017 diyAudio
