#3581 |
Attached pic 6V6, it's OK?
#3582 |
Have anyone tried 6V6 preamp with transformer output?
#3583 |
diyAudio Chief Moderator
@merlin
Schema 6v6 ok. Try no gnd, full gnd, to see. Use fuse, even glass one for now. |
#3584 |
#3585 |
I will use two diodes in series for voltage doubler, I changed all CCS area: resistors & both DN2540, also I will included all zeners 12V 05.5W that I didn't installed, local shop don't have 500V: could I use two fuses in series 100mA 250V or in parallel?
#3586 |
Use two fuses 100mA in series with 2 cm distance between their holders. So they can interrupt without arc.
http://www.youtube.com/watch?v=MAlyEMQxTN0 |
#3587 |
Can I use zeners 12V 1W to replace 0.5W?
#3588 |
Yes
#3589 |
Salas see attached pics, If I don't see I don't believe: 300 ohms PSU Caddock MP820 with big heatsink.
#3590 |
I have connected the regulator but the red LED has not lit and neither I have voltage at the output
![]() First I will change Q6 2SK117GR to see if LED lits.
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
