Simplistic Mosfet HV Shunt Regs - Page 357 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th December 2012, 10:43 PM   #3561
roger57 is offline roger57  Canada
roger57's Avatar
Originally Posted by Salas View Post
Yep it may, but the Supertex one underneath does the current. The IXTP shields HV.
(68Kx2)*K117 max in circuit current=Vo max.
Assuming the 2SK117 that's in there now is the component "limiting" the voltage to 340V, I would find it's Idss less than (approximately) 2.5mA?
So I should find one 2.8mA or better? (by your formula)
Gary
Old 9th December 2012, 10:59 PM   #3562
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
3mA in circuit should go full tilt 400V. They give bit less IDSS than free with a battery when in circuit due to less VDS there, so a 3mA free should suffice.
Old 9th December 2012, 11:01 PM   #3563
Salas's Avatar
Another way is 75K 2W resistors instead of 68K if short of JFETs
Old 9th December 2012, 11:46 PM   #3564
roger57's Avatar
Salas,
BTW - I did not yet substitute a 1 ohm for the 10ohm sampling resistor, I do not have a 1% MF.
I found a strong 2SK117 with an Idss of 5.6mA (using the 9V battery test)
However, it did not make so much of a difference.
I can now readily get the output to 350V, at 80mA. However, that's with a minimum of 420V in. If I drop below that, the output falls pretty fast. I think that's a maintainable number (420V) for Vin, since it's coming off of my plate supply, but why would I need 70V overhead to maintain a Vo of 350V??
Very odd, the other board id not behave like that at all!
Old 10th December 2012, 01:57 AM   #3565
roger57's Avatar
OK, I found the problem. Time for a break while I fix my head...
Ok, all better now.
I had 2 resistors in series for the load, a 5K and a 820 ohm. I had my meter clipped across just the 5K.
Next time I'll look a bit closer before I send an SOS.
Sorry to bother you Salas, and thanks for your help.
Gary
Old 10th December 2012, 04:35 AM   #3566
Salas's Avatar
No shortage in semis IDSS then, wrong load. Happy end.
Old 10th December 2012, 06:06 PM   #3567
merlin el mago's Avatar
Salas could benefit the SSHV2 adding before a cap multiplier?
Old 10th December 2012, 07:10 PM   #3568
Salas's Avatar
The multiplier will ruin the flat low Z. Rather not. If you meant putting the mult before, rather yes. But use output cap on the mult to avoid it will ring with CCS.
Old 10th December 2012, 08:06 PM   #3569
I ask because as you know I use an AZ1 so PSU can have more than 60uF, could you link me to a schematic or thread where I can get the information?
Old 11th December 2012, 01:25 AM   #3570
Originally Posted by king4joy View Post
Final testing of new PSU with 150K bleeder only. V out = 377V
Salas....I changed the shape of the heat sink and now I am fitting two SSHV2 boards in my PSU box....
I will set each board to about 30mA giving about 8-9mA to each VT25A tube.
If I connect 2 x SSHV2 boards to the PSU instead of one SSHV2, do I need to change the bleeder value or other parts of the PSU??
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 06:49 PM
Copyright 1999-2017 diyAudio
