Simplistic Mosfet HV Shunt Regs
Old 30th November 2012, 06:55 PM   #3541
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Could you post schematic? pics?
Old 30th November 2012, 10:52 PM   #3542
rickmcinnis is offline rickmcinnis  United States
Default Merlin, are you speaking to me?
There is not useful schematic for the PCB. Plenty of schematics for the circuit, itself.
Here is a link to the manual at Broskie's site. http://tubecad.com/2008/07/13/PH-1%20Phono%20preamp.pdf
Look on page 11.
One can easily use the resistor positions on the B+ rail for the regulators but the grounds ....
Thanks for your interest.
Rick McInnis
Old 1st December 2012, 08:30 AM   #3543
king4joy is online now king4joy  Hong Kong
Originally Posted by Salas View Post
OK, we cross posted. Those numbers SSLV1.1 can do with IRF9530 at CCS position also as it has on output already. And its better spec than the the BJT special one for 1.5V-2.5V I designed for disco once. You set it at 1.5A and Bob's your uncle.
Salas.......For Q101, have you changed to use IRF9530 as well?? better??
What is CCS current setting and CCS-LoadCurrent?? The filament is burning at 1.25-1.50A....will there be lots of heat at Q106??
Could I use 9V-0V-9V 3.3A transformer per channel??
King
Old 1st December 2012, 10:36 AM   #3544
Look on page 11.
What's the problem with the grounds? Or do you use two regulators with different B+ for each channel?
Old 1st December 2012, 05:01 PM   #3545
Default Reply to merlin
That all of the regs will be the same is my intention.
I know this would not be a concern with four passive supplies but the sensing connection of the SALAS regulator had me concerned that there could be some kind of unwanted interaction.
Rick McInnis
Old 1st December 2012, 05:37 PM   #3546
I never tried, but why do you want to do four regs? what's the total consumption of your Aikido?
Old 1st December 2012, 07:12 PM   #3547
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I am building four of the regulators to power a Broskie Aikido phono board using TEA BAGS pcbs (thanks again, TB)
It is basically four of the AIKIDO circuits on one board.
I am using four since I have ECC99's in the cathode follower position and these seem to require more than average current so I figured why not use four?
It is simple to connect the positives to the individual "modules" and they are isolated but PCB surgery (not that I am afraid of this) is required to isolate the individual grounds. The question is: is it necessary?
My instinct is that it is but I thought I would ask before starting the procedure.
Help is appreciated and my apologies for not knowing the answer to this myself.
THANKS!
Yes, it is necessary if you want the Kelvin sense system to work best, and its audible when it does so.
Old 1st December 2012, 07:13 PM   #3548
Salas's Avatar
King
In SSLV1.1 builds thread for the LV questions. Thanks.
Old 1st December 2012, 07:15 PM   #3549
Salas's Avatar
Originally Posted by Milos P. View Post
hmm... 2N5457?
No, dangerous for coming up with a high Vgs(off) sample relative to the purpose here even at low IDSS.
Old 1st December 2012, 08:18 PM   #3550
Milos P. is offline Milos P.  Serbia
OK, thank you.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
Copyright ©1999-2017 diyAudio
