Simplistic Mosfet HV Shunt Regs
Old 18th November 2012, 05:13 PM   #3461
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Inspect the passives well. Maybe a zap has hit the belly of the caps or something inside them. Push them up half a mm off board for a check.
Old 18th November 2012, 05:41 PM   #3462
Jogi is offline Jogi  Germany
Q2 replaced, voltage in goes up to 330V, out still 240V, now I can't adjust current anymore, only between 5-6mA, input Voltage then varies between 330-340V...
Old 18th November 2012, 05:42 PM   #3463
caps are safe btw
Old 18th November 2012, 05:49 PM   #3464
Salas's Avatar
Is there Vgs in Q1 and Q2,Q3? (Watch it when you probe). Have you got an LCR to measure the caps for value and dissipation factor?
Old 18th November 2012, 06:12 PM   #3465
Caps have 10 and 0,32, as they should. Dissipation factor I can't measure, also I'm pretty clueless how to measure the Vgs. Maybe I just replace the 840, I've just one left.
Old 18th November 2012, 06:27 PM   #3466
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Vin 12VDC, R5 50 ohms, measured at TP 0.3A = 30mA, it's OK?
Old 18th November 2012, 06:37 PM   #3467
Simple measure voltage between Gate & Source
Old 18th November 2012, 06:49 PM   #3468
Salas's Avatar
Maybe R4 pot value at 50 Ohm you meant? And 0.3V over T.P. you meant? R5 is a fixed 10 Ohm resistor as it should, yes?
Old 18th November 2012, 06:53 PM   #3469
Yes, R4 trimmer set to 50 ohms, yes 0.3V over T.P., yes R5 10 ohms fixed resistor.
Old 18th November 2012, 06:55 PM   #3470
Salas's Avatar
Goes to plan then. Sit C1 and C2 like they don't touch free pads for just a little when you will complete it.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
