#3451 |
Do you know how to make a simplistic +50V PSU?
#3452 |
Can I do it with a LM317?
#3453 |
diyAudio Chief Moderator
You just need some +DC voltage to test the CCS independently I understand. So whatever you got up to 50V (to keep dissipation under control) its OK. Be it batteries, LM317, bench PSU, whatever. It could be 12V even.
#3454 |
OK I will do.
#3455 |
A new Salas SSHV2??!!! Please keep us posted.
#3456 |
not politcally affiliated
That would be a SSHV3
![]() Really, no idea.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#3457 |
Merlin's photo where the still unpopulated C1 pads can be clearly seen is an opportunity to remind something for when constructing. Only the two left hand pads are to accept C1's one leg, all the others to the right are to accept its other leg. They are staggered for various standard pitch capacitors that you may find. Watch the legs to always span the left black gap in the picture in other words, and keep the cap just a wee bit proud off board for its underside not to touch any free pads, its important.
@KingForJoy That ain't any new SSHV2, its just Merlin's yet another SSHV2 build. |
#3458 |
o.k., I just feel the need to get out the sledge hammer for treating my SSHV2 built
![]() ![]() Its for my D3a phono preamp, which played nicely with the first version of the shunt. I then set up the SSHV2, clearly better...and then I accidently shorted the input, and from then I replaced 3 sets of semis and couldn't get it running again. Ruined the PCB of course during the process. Then I asked a friend to let go of one of his spare shunt PCB, ordered new semis and populated everything completely new; worked fine yesterday from the beginning. When trying to mount it in the encosure, I again shorted the input accidently! (by just one strand of the wire which was peeking out of the bundle) Before I had 290V input / 240v out set at 50mA, tubes eating 25mA. Now when I set the current to 50mA, the input voltage drops to 243V, out still at 240. When setting current to 30mA, input gets up to 280V again, but current ist too low. And in either way the IRF840 is getting pretty hot, so something is eating a lot of current here. I still can adjust both trimmers, and I already replaced Q1 to no avail. Before I order new semis AGAIN and tear everything apart and replace all semis AGAIN, does anyone has a hint where to look first? Maybe you know the feeling when you just want to open that window and get rid of the problem the easy way |
#3459 |
Replace C1, after that C2, see if it behaves any better, maybe they got a hit inside the windings. Inspect with a strong light and/or magnifier when installing HV stuff. Two times shorting is big jinx.
#3460 |
Yes, really bad kinda magic...
Thanks Salas, I'll try the last remaining semi for Q2, hoping for the best... |
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
