#3361 |
diyAudio Chief Moderator
The Zeners and/or the FET are suspicious. The FET especially goes pop without drama in over voltage. But check the CCS works after R1 change and possibly D1 or worse Q1. See at 12V as you say. It was left on how high a voltage input for 5sec?
#3362 |
230V input voltage, and it may have been 10 sec, since i had time to take the multimeter measuring. 100mA load.
Will check the zeners also. By fet you mean the IRF840? |
#3363 |
No, the JFET. 230V to 13.5V * 0.1A hmm, it gave Q1 some stick for 10 sec. Proceed to step autopsy.
#3364 |
the Q1 sink didn't become that warm, but the R1 did burn, so it may have lived through it.
So i will try change the Q6 then, after i have checked the CCS part. D3 seems like a candidate which may have died? |
#3365 |
Yep.
#3366 |
Changed all diodes, since they seemed to be broken (i got contact on them both ways with multimeter), then i changed the R1 and the JFET. Tried measure all resistors on board, and it looked right. tested the CCS with 12v between +input and +f which worked fine.
plugged everything in, started with 230v filtered input, and R1 burned again. Seems like something with the shunting? |
#3367 |
Do the replaced diodes do the same conducting when off circuit? The 840's gate oxide could be hit when sparking, you are not left with much to check. That and the two BJTs.
#3368 |
Sorry if this question has already been posted; did some searching but could not find. Please reply with posts if already answered or threaded.
Has anyone set up an SSHV2 with about 450V input (about 30mA at load required), and what components were changed (need to be changed) ? Thanks, Gary |
#3369 |
If the Jfet has enough Idss you can got about 400V out without changing anything, about input over 400V me no, because the CCS Mosfets are 400V rated, though that condition is over run only just before the output develops, but at your risk.
#3370 |
RollE2K, does your DMM light up LEDS in diode mode? Has 2-2.5V? See that the LED can still light up to be sure before proceeding.
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
