Simplistic Mosfet HV Shunt Regs - Page 336 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th October 2012, 12:59 AM   #3351
Salas...I have closed circuit at the branch point, and made connections to the 2 tube with equal lengths (14 inches) wires....work out perfect....thankyou.
Old 19th October 2012, 07:18 AM   #3352
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Originally Posted by merlin el mago View Post
1/are the Lundhals
2/I assume you don't need more gain or inductance, how do you know if you need or don't need more inductance?
1)with the #26 tube expect around 300Ohm with ll1660 wired 4,25:1
2)intact audio
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 19th October 2012, 05:28 PM   #3353
merlin el mago's Avatar
George how do you wired the TVCs, like attached pic
Old 19th October 2012, 05:34 PM   #3354
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Where to take the TVC dialogue so to be useful for members looking for? #26 thread? Here is OT, nobody will look for TVC in the PSUs forum.
Old 19th October 2012, 05:50 PM   #3355
I'm sorry Salas
Old 20th October 2012, 10:14 PM   #3356
RollE2k is offline RollE2k  Sweden
OK, so i had my SSHV2 up and running on my testbed. Did some modifications to my DC-filter (new choke) and plugged it back. Accidently the output positive twisted wires was loose and i got a short circuit between the positive and negative.
I powered off, and it didn't look like anything was damaged. Except when i powered on i had ~13.5v output, and after maybe 5 sec, the R1 burned.
I don't see any visible damages to any other components, but something must be broken. Maybe any diode? any idea where i should start, or what i first should check?
I'm thinking about putting a 12v input and ground it a the testpoint, just to check the CCS-part first..
Old 20th October 2012, 10:53 PM   #3357
Salas's Avatar
That's a good idea to test the CCS first, it shouldn't be left running after the fault. I would test/change Zeners and JFET first.
Old 20th October 2012, 11:03 PM   #3358
Thanks alot Salas, have to do that tomorrow then, probably not that hard to fix - but it is always good to have any idea where to start!
Old 20th October 2012, 11:04 PM   #3359
Salas's Avatar
Did it spark when it shorted loosely by the way?
Old 20th October 2012, 11:17 PM   #3360
Yes it did spark, any idea more exactly what probably have been damaged?
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 05:49 PM
Copyright 1999-2017 diyAudio
