Simplistic Mosfet HV Shunt Regs
Old 18th October 2012, 02:11 PM   #3341
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by vgeorge View Post
Transformers wired 4,25:1 stepdown as I told you before.
Try to think about it when you relax!
Definitely yesterday was very very tired, I'm sorry for misunderstanding about TVC gain but I know there is some TVC with gain....
Old 18th October 2012, 06:20 PM   #3342
nicoch58 is offline nicoch58  Europe
Quote from Dave about TVC
"Yes, some people report good results but be aware that wiring for 6dB of gain means that the source will see only 1/4 the inductance of the full winding. Stacking the core with more interleave will recover the lost inductance, though the ultimate success may depend on your system and your requirements."
Old 18th October 2012, 06:53 PM   #3343
Do you know or post a link how to be wired for 6dB of gain?
Old 18th October 2012, 07:33 PM   #3344
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Felipe,
do you need that extra gain? Also don' t forget that output impedance will go up with 6dB gain.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 18th October 2012, 08:02 PM   #3345
George,
Do you know the output impedance setting to 6dB gain?
Have you played with different inductance in yours TVC?
Old 18th October 2012, 08:21 PM   #3346
vgeorge's Avatar
1)it depends on the output impedance of the stage before the TVC. How much lower, better ask Thomas Mayer who is an expert on this.
2)no, as I couldn' t find a reason to increase the inductance.
Old 18th October 2012, 09:26 PM   #3347
1/are the Lundhals
2/I assume you don't need more gain or inductance, how do you know if you need or don't need more inductance?
Old 18th October 2012, 09:44 PM   #3348
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by king4joy View Post
""...You bridge the points of psu interest in the audio circuit...""...not quite understand exactly...please explain a bit more....
Cheers....
If you got two B+ local points to feed for two tubes, link them and put F+,S+ as a midway node for example.
Old 18th October 2012, 11:04 PM   #3349
ask Dave Slage intactaudio ....
Old 18th October 2012, 11:08 PM   #3350
I will ask, thanks.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
