Simplistic Mosfet HV Shunt Regs
Old 17th October 2012, 06:12 PM   #3301
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by king4joy View Post
PSU with SSHV2 installed awaiting testing.
Dummy load = 10K/50W.
Are those capacitor bottoms with wires exiting from black blobs belonging to Obbligato film in oil cans?
Old 17th October 2012, 06:14 PM   #3302
Salas's Avatar
Originally Posted by merlin el mago View Post
I didn't expected such difference.
Tubes can be very synergistic between them sometimes. Just keep what you like best.
Old 17th October 2012, 06:25 PM   #3303
merlin el mago is offline merlin el mago
merlin el mago's Avatar
If the the same synergy with the #26 tue preamp now I understand why sound so good, thanks Salas for all support & giving the best sound really appreciated.
Old 17th October 2012, 06:31 PM   #3304
Salas's Avatar
I had listened to very good #26 config with trafo pot and 2 SSHV2, Rod on cathodes, trafo out, the works, at VG's through his nice big horn speakers. It gives that golden tone. Although I could easily say it was a form of DHT coloration when he sent me files directly from vinyl riaa pre or through 26 also that I checked on headphones, in the listening room's acoustic space it was very engaging.
Old 17th October 2012, 06:36 PM   #3305
I have two trafo pots & two outputs tx, just now I'm wiring the TVC to my Shallco attenuator.
Old 17th October 2012, 06:47 PM   #3306
iko is offline iko  Canada
iko's Avatar
Just curious, do you have a slight preference for your 6V6 preamp over the 26?
Old 17th October 2012, 06:53 PM   #3307
Salas's Avatar
I did not have the opportunity to listen to them A/B in the same system. If I am grasping it right the 6V6 one has more fleshed out and neutral tone, the #26 has that illusive DHT touch of golden halo open mid-highs.
Old 17th October 2012, 07:01 PM   #3308
Salas's Avatar
Someone has to use same TVC, regs, etc. to be fair and listen in the same system of course. The 6V6 can get you to very good level cheaper with less problems to solve and less subsystems is one sure thing. A TKD, or Cosmo 50-100K, 100 Ohm good grid stopper, 7.5K Mills load, 300V clean B+, good capacitor output, and you are there.
Old 17th October 2012, 07:08 PM   #3309
I will do a look because all people said #26 are very microphonics.
Old 17th October 2012, 07:13 PM   #3310
Salas's Avatar
6V6 can also be enough. Both need anti vibration mounting.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
