#3261 |
@Salas
How can increase the current, max current can get are 20mA with +280V (with dummy load & ECC81 preamp), it's due to use AZ1? |
#3262 |
diyAudio Chief Moderator
It probably does not give you more constant current, if it could the reg would hit 100mA+
#3263 |
I ask Rod.
#3264 |
Rod said 50mA....
#3265 |
Yours does not, obviously. What are the differences? He uses CLC, you use one capacitor. Now what are the values for all those? What transformer secondary he specifies? 50mA at what voltage? Something is not optimized in your case for 50mA constant current to be drawn at the voltage level you require from that small vintage rectifier tube. You use just 6mA for your audio tubes you are lucky.
#3266 |
Possible be the tx I will try with another 240VAC or I will use both in parallel to have more current.
#3267 |
Gotcha was using only one tx giving less current than needed, with 2 tx in parallel I measured 25mA with B+ +280V
#3268 |
You mean two secondaries or an actual 2nd transformer? What kind of VA is its spec? Should have had high impedance and lost a lot of voltage.
#3269 |
I use two tx in parallel, I don't know VA rated, both are used in an Audionote DAC with two ECC88/6922, measured two secondaries in parallel give me 58 Ohms.
#3270 |
Salas...further to my post #3182...I have moved the second choke to parallel with the first choke....now with no load....the PSU output (accross the bleeder resistor, a 22K/50W) = 295V....and when I connect a dummy load of a pair of parallel 10K/50W that I have on hand (I hope it will be close enough to 6.4K)...the output = 271V....is it possible to work out the value of the bleeder to give say about 290V to the SSHV2 as input....to get 270V output from it please??......I will remember to send photos after it is all finished....cheers....
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
