Simplistic Mosfet HV Shunt Regs
Old 8th October 2012, 02:47 PM   #3231
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I simulated with PSUDII, can't get me simulate open new window:
"a current sink has pulled the voltage below 0 for more than 5 mains cycles, at time 0,100038S"
If I press anyway OK button open other new window:
"the rectifier IFRM (current forward repetitive maximum) of 0,75A has been exceed with a value of 1,25A, at time 2,181013S"
Old 8th October 2012, 03:05 PM   #3232
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Don't know what AZ1 can do in constant current situation maybe its not taking it well. Ask Rod since its not burning something in the reg.
Old 8th October 2012, 03:08 PM   #3233
Sent a pm to Rod, thanks Salas.
Old 8th October 2012, 03:15 PM   #3234
BTW I Measured VDC after the first 26uF without reg 354,8VDC
Old 8th October 2012, 03:24 PM   #3235
Salas's Avatar
Merlin calm down, without load tube rectifiers with chokes also shoot higher. How much is normal in your situation I don't know. There you have a full preamp, Rod's design. Here we know nothing but the reg. Reg works back, fortunately no damage. I would make test suggestions but it is not appropriate to start reverse engineering that when Rod is active and helps you. The schematic you posted does not even have voltages on it.
Old 8th October 2012, 03:27 PM   #3236
Isn't important because I want to use the reg for ECC81 mu-follower preamp not #26 preamp.
Old 8th October 2012, 03:30 PM   #3237
pic
Old 8th October 2012, 04:27 PM   #3238
Salas's Avatar
Do something different. Use AZ1 alone, without the extra diodes, see what happens. Use full SS bridge, see what happens.
Old 8th October 2012, 07:16 PM   #3239
10y is offline 10y  Italy
Default ccs resistor value
What is the right resistor value in order to set ccs of my salas HV shunt reg for a current value of about 30 mA ?
I would supply two #26 at 5,5 mA max each. I have two 30 ma choke on HV line in a c-l-c-l-c configuration and would not saturate them . As I also have other two spare similar 30 ma choke, can I put them in parallel in order to increase max current value?
Thanks for your helps!
Anto
Old 8th October 2012, 07:20 PM   #3240
Salas's Avatar
Talking SSHV1 I suppose?
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
