Simplistic Mosfet HV Shunt Regs
Old 8th October 2012, 12:02 PM   #3221
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You need more Vin. Yes the reg draws same ccs without a load also, only it burns it all on its output sink. Never connect the probe live!!!
Old 8th October 2012, 12:23 PM   #3222
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I'm using tx 240VAC isn't enough for AZ1?
Old 8th October 2012, 12:29 PM   #3223
I'm using Rod Coleman AZ1 psu, only different after the tube one cap 200uF and after the SSHV2
Old 8th October 2012, 12:30 PM   #3224
There is other way to increase the voltage using AZ1 without changing the tx?
I can't get the way to simulate with PSUDII.
Old 8th October 2012, 12:43 PM   #3225
Salas's Avatar
Ask Rod, if paralleling L1 L2 can help.
Old 8th October 2012, 12:49 PM   #3226
I don't use C-L-C-L-C, I use only C 200uF between the AZ1 and your SSHV2.
There is other way to use the diodes or without diodes to increase voltage?
Old 8th October 2012, 12:54 PM   #3227
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
200uf is too much after the AZ1. According to datasheet max is 60uf
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 8th October 2012, 12:58 PM   #3228
Thanks I will lower the value to MKP 27uF 400VDC to see what's happen.
Old 8th October 2012, 01:17 PM   #3229
Vin +287VDC still too low, red led don't lit with real load. I can use two 240VAC in series to have 480VAC but is too much?
Old 8th October 2012, 02:18 PM   #3230
Can I use two 240VAC in series to have 480VAC or is too much?
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
