Simplistic Mosfet HV Shunt Regs - Page 322 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th October 2012, 10:49 PM   #3211
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What happens if you go down to 25mA?
Old 8th October 2012, 09:49 AM   #3212
merlin el mago's Avatar
25mA same issue, tx is 240VAC could be the problem?
Old 8th October 2012, 09:56 AM   #3213
Salas's Avatar
You said on dummy no problem, less current same stuff, so it must be on the output side. Checked 4 wires not wrong by mistake? If no mistake scope for no big oscillation on the power lines. Probe 1:10, scope on ACin, 10mV/div see for clean DC line, stay safe its HV.
Old 8th October 2012, 09:59 AM   #3214
4 wires are OK, can I do the test for no oscillation with the dummy load?
Old 8th October 2012, 10:11 AM   #3215
Salas's Avatar
Dummy test first so to see the led works, there is output, all ok as before.
Old 8th October 2012, 10:13 AM   #3216
OK
Old 8th October 2012, 10:15 AM   #3217
Oooooops Salas, when I connect the probe gnd to the dummy load gnd a big spark lit!!!!!
Red led lits & have 280Vout on the dummy load.
Old 8th October 2012, 10:18 AM   #3218
Connected again the DVM: dummy load still haves +280V
Old 8th October 2012, 10:23 AM   #3219
Vin at the reg is only +287V with the dummy load connected
Old 8th October 2012, 11:12 AM   #3220
Vin at the reg is only +287V also without the dummy load connected
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 05:49 PM
Copyright 1999-2017 diyAudio
