Simplistic Mosfet HV Shunt Regs
Old 6th October 2012, 06:32 AM   #3191
king4joy is offline king4joy  Hong Kong
What would be the best way to fine adjust the PSU to get 290V for the SSHV2 board please??
Old 6th October 2012, 06:41 AM   #3192
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Load your PSU's output (disconnect preamp) with resistor that asks 45mA at 290V and tune until you get about 290V I think. 22K//18K//18K 10W each. Then disconnect them and it will give the same if you connect SSHV2 set at 45mA.
Old 6th October 2012, 06:45 AM   #3193
22K//18K//18K 10W each.....parallel with the bleeder resistor to adjust for 290V out??
Old 6th October 2012, 06:49 AM   #3194
Salas's Avatar
No, across output capacitors to the right.
Old 6th October 2012, 06:53 AM   #3195
Salas's Avatar
Those will be just dummy load so you will be able to adjust your bleeder, see how much the rectifier sags, see your series drop on the chokes. And to try for 280V-290V.
Old 6th October 2012, 06:53 AM   #3196
Salas's Avatar
Or you simulate on PSUDII. http://www.duncanamps.com/psud2/index.html
Old 6th October 2012, 07:00 AM   #3197
OK...ok...understand....put a dummy load that will draw about 45mA at 290V....and adjust the value of the bleeder resistor to give 290V at the dummy....
Old 6th October 2012, 07:18 AM   #3198
interesting....after moving out the second choke....the bleeder looks like a load resistor....yes??
Old 6th October 2012, 07:36 AM   #3199
so I will use a 6.4K 10W as load; and adjust bleeder to give 290V...then remove the 6.4K, and connect the PSU to the SSHV2.....and I use a 11.6K as a dummy at the output of the SSHV2....
Old 6th October 2012, 07:45 AM   #3200
Salas's Avatar
10W will melt, 290V*0.045A=13W. That is why I suggested 22K//18K//18K 10W each. You need about 2 times the dissipated power in nominal resistor power to get very hot and 3 times to get rather comfortably hot. Your bleeder is now direct part of the load after the chokes move, yes. The other things you wrote are correct.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
