Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th October 2012, 05:55 PM   #3181
asdiasx is offline asdiasx  Brazil
asdiasx's Avatar
Send a message via MSN to asdiasx
Default Example....
I found an example... as I said, the concern is related to the transformers specifications....
Adriano Dias
Old 6th October 2012, 04:42 AM   #3182
I have bought a SSHV2 kit from TeaBag a while ago, but only have time to finish it recently, awaiting testing.
The SSHV2 will be used in my SET line amp with a pair of VT-25A. Each VT-25A is loaded with a CCS (C4S) setted at 12.5 mA.
The original PSU is as attached.
Do I need to modify the PSU for the best performace??
My worry is, the chokes are only rated at 40mA each and I need to set the T.P. to 45mA (12.5 + 12.5 + 20). Do I need to parallel the two chokes??
I plan to set the out-put of the SSHV2 at 270V for the amp....
Any suggestions/recommendations will be welcome.
Thankyou and cheers,
KIng
Old 6th October 2012, 04:49 AM   #3183
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes you will need to parallel them so they can handle the 45mA constant current asked by the regulator they will now have to feed. This will also allow for less voltage drop across the pre-filtering. Your minimum input for good 270V output from SSHV2 should be 280V input. 290V is recommended to allow for mains play. Still if you know it will never give less than 280V DC to the reg in your area, then its enough. The tube rectifier needs to allow at more current now also.
Old 6th October 2012, 04:56 AM   #3184
Thankyou Salas....so I should move the second choke to parallel the first one...and still keeping all the caps....and I will try for a 290V by adjusting the value of the resistor...thankyou again...
Old 6th October 2012, 04:58 AM   #3185
Forgot to mention, the original box does not have enough space for more chokes....I am stuck with the part count....
Old 6th October 2012, 05:04 AM   #3186
Salas's Avatar
If you can have your last 22uF cap nearest to reg's input its good, it decouples the inductance along the road. What you already have is pretty nice for keeping as rectification and passive filtering to the reg. Helps.
Old 6th October 2012, 05:08 AM   #3187
Salas's Avatar
P.S. Good luck, I wish success. Post us a photo of the finished system when all is done, and let us know if you liked the passive as is or with the reg better.
Old 6th October 2012, 05:15 AM   #3188
Salas's Avatar
Originally Posted by asdiasx View Post
Hi Salas, sorry it wasn't clear... Let me try to explain graphically:
(home AC outlet 120V)=======(1st Trafo pri120V/sec220V)==========(2nd Trafo pri120+120V/sec12V)============(Ac output 240V)
120V ==================== PRI // SEC ===================== SEC // PRI ============================ 240V to rectifier/regulator
My concern (if it is possible) is to specify the trafo secondary current, so I can get enough current at the output....
Your primaries current ability should not change if you use them back or forth. So it should be what it was given by the manufacturers as primary max mA. I am very basic in transformer tricks knowledge, maybe I am wrong.
Old 6th October 2012, 05:29 AM   #3189
The SSHV2 board is just next to the 22uF....
is it OK if I move the second choke to parallel with the first input choke....and leave the rest the same (the PSU will become a LC type)...
But the board is about 12" away from the CCS's for tubes, and I hope it will work out fine.
Old 6th October 2012, 05:32 AM   #3190
Yes, I will post photos when it is finished....
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
