Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th September 2012, 09:52 PM   #3151
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
So 12mA assuming 2 channels since you mentioned 1 SSHV2, +20mA allowance, then set for 35mA. The Led is in series with the voltage reference. Should always shine when there is current there. Something's wrong outside the reg since it worked on dummy. Verify that its still good by using the dummy once again and set higher ccs than before. Maybe an oscillation flashes some energy when you touch probes. Still it should be shining anyway when all is well.
2 things may trouble you on first approach. 1. Too much current went to the pre for your CCS setting, not enough left to power the reg's innards. Can it be it draws more than 6mA each valve as usual for #26 preamps due to low B+ bias point, and 25mA was truly marginal, leaving the reg breathless? 2. The 4 wire system maybe is not routed correctly to the preamp and the reg's sense reference circuitry sees no power from the main force lines not meeting them properly to the load's side. Verify that +sense & +force go together to B+, same for the other two to ground. At least the 0sense and 0force wires should meet at a symmetric as possible grounding node between the preamp's channels.
Old 18th September 2012, 07:30 AM   #3152
CSlee is offline CSlee  United Kingdom
Clueless
CSlee's Avatar
Thanks - I will follow your steps and report back.
Cheers
Charlie
Broke solderer with delusions of grandeur
Old 18th September 2012, 09:40 AM   #3153
If the shunt FET is designed to survive the worst case operation. Survive not operate perfectly during the fault condition, but return to perfect working after the fault condition is removed.
This Shunt FET worst case survival is Tj < Tjmax when the output is open circuit, i.e. the fuse is blown or the output has simply been disconnected.
If your Shunt meets this requirement then you don't need any dummy load.
The Shunt will pull down the output voltage to the set point and hold it there while the Shunt Tj rises far above normal. The output voltage will drift as this happens. But you only need a few seconds to confirm that all the lights are on and that the set point voltage is about right.
I consider survival in the two worst case operation to be an absolute requirement for any regulated PSU that I build.
Shorted output when mains voltage is maximum
and
Open circuit output. Mains voltage does not matter.
Old 18th September 2012, 12:38 PM   #3154
Salas's Avatar
Those are things that shunts in general may survive if the sinks are big and there will be no arcs, but I don't recommend to nobody non trained electrician to try test such conditions in SSHV regs, i.e. doing shorting tests when a reg is handling high voltage or to leave it open circuit when his sink is not calculated for max. Builder please be conservative and follow the pre testing procedure on helper dummy for the power and heat to be divided between reg and load. Be super careful, high voltage can kill. When wiring and probing think your moves twice. If it will ever accidentally short or stay long without a load and will get too hot it may survive depending on the severity and byproducts of a fault, your settings and sinks, just retest it by the original procedure if in doubt. Always fuse the primary of the power transformer to its mains draw mA spec.
Old 18th September 2012, 09:23 PM   #3155
Clueless
CSlee's Avatar
Went back to the dummy load and it was working well again. So I rebuilt the raw supply to give it some more breathing space and reconnected. Everything is working fine now so I was just not allowing for enough voltage for both reg and circuit. Actually, everything is working really well....
Thank you so much for designing this, it has really helped me understand these complex regulators and am looking forward to using them more.
Cheers
Charlie
Old 18th September 2012, 09:33 PM   #3156
Salas's Avatar
Did you set 35mA also?
Old 18th September 2012, 09:43 PM   #3157
Clueless
CSlee's Avatar
I did. I am currently using one board to run both channels (because I was impatient) but will build the second board tomorrow. It is really interesting to see the relationship between the raw supply current source and reg, learning a lot!
Charlie
Old 18th September 2012, 09:51 PM   #3158
Salas's Avatar
I just saw a picture you posted in the number 26 preamp thread. Looks nice and you sound happy. I have listened to that line pre in transformer pot and output config at Vgeorge's place on his ''beyond the ARIEL'' based modular horns. A musical preamp. Enjoy.
Old 18th September 2012, 10:08 PM   #3159
Clueless
CSlee's Avatar
Thanks! I am really looking forward to getting to know it.
Thanks again for the great boards
Old 19th September 2012, 06:55 AM   #3160
This sounds like you are suggesting that the HV version of the Salas Shunt does not suit survivability in the event of the output becoming open circuit.
That type of error whether by accident (fuse blowing, or wire breaking loose) or human error in leaving the output open when powering up, could be quite common.
I don't agree that a failure of the Shunt regulator due to this worst case operation is a risk that many builders will want to take.
I can see that the shorted output when full mains voltage is applied is a much less likely worst case operation and many builders may be prepared to accept this risk, of shunt failure, in this situation.
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
