#3121 |
Salas,
I see many builders are using a low voltage device for M1. M1 takes enormous stress at start up for a few us or ms depending on the load characteristics. Is there a history or good, or poor, or bad, reliability for the M1 devices? |
#3122 |
diyAudio Chief Moderator
Although it started as a what I had in the parts bin thing, very good M1 reliability. Seems that the small Vref filter cap (1uF) does not stress them long enough at start up.
#3123 |
Yes, there is only 1uF and 1uF+3r3 as a start up load inside the regulator.
What is the external load capacitance? I will point out that I believe a lot of the good performance of these Salas Style regulators comes from the fact that very few capacitors are used. |
#3124 |
Back to #3118,
Why is R3 so large? Would a much lower value suffice? Like 220r or 470r? |
#3125 |
I don't remember why that value, really. On the lower range circuit it was sub 1K indeed.
Its 4 years now that initial circuit and I arrived there on test, it wasn't simulated before. *Few caps and no significant lytics was a a quality and economy goal. **Maybe he needs an input decoupling film if he has got long wires. |
#3126 |
Just a question: as I see it, the collector of Q3 is kept at 1,2 volt.
Then I see a mismatch with the base of Q1 at [at least] 0,6 volt. So maybe this design needs a darlington at Q1? on the other hand, this idea could work when using a NPN pair current source and proper termination at 'the top'.. apologies for a maybe stupid question.
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
#3127 |
No,
the collector of Q2 is @ ~ 1.3V below the output rail. The base of Q1 is @ ~ 0.65V below the output rail. This forces Q3 to a Vce of <0.1Vce. i.e. Q3 is saturated. Not a good way to ensure good performance from a two transistor CCS. That CCS determines the current and thus the voltage drop across R9. Your idea of a darlington for Q1, or maybe a mosFET, would help get Q3 Vce back up to at least 0.5V and maybe towards a couple of volts. Last edited by AndrewT; 13th August 2012 at 11:58 AM. |
#3128 |
Hi Salas,
The regulator is stable after making R10 as 4k7. Thanks!!! Q1 will now also dissipate less heat. Is there a drawback to this? --- How hot does R9 become? Be careful it has a lot of volts across it ! AndrewT, it is not hot, only a little warm. Regards, -MW |
#3129 |
eboz, nice. No problem, its better gain and less dissipation that way. I had revised that when I had used it near max Vo a long time ago, its 4k7 on the schematics from back then also. So you are at standard.
#3130 | |
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
